fergavs wrote:See here
http://www.dieseltruckresource.com/pics ... hoto=40198
Someone feel free to grab the pic and put it on here if you would like.
PToombs wrote:The pump has to come all the way apart. Totally. You need to pull the shaft, and then clean it when the machine work is done. I've heard that loose metal in the IP might be bad.
RSWORDS wrote:In all reality, how hard is it for a weekend mechanic to take apart and rebuild a pump?
