full power screw
Postby mhuppertz » Thu Jun 28, 2007 8:23 am
When I advance my pump a tooth wont that give me better access to the stuff on the back of the pump?
mhuppertz
Postby wannadiesel » Thu Jun 28, 2007 4:39 pm
Yep. It will make setting the idle a lot easier.
Best dyno: 408/844
wannadiesel
diesel guru
Postby PToombs » Fri Jun 29, 2007 1:17 pm
It's even easier if you take it out and put it in from the front! :wink:
Postby CAJUN 93 » Fri Jun 29, 2007 2:28 pm
PToombs wrote:It's even easier if you take it out and put it in from the front! :wink:
something about that just sounds funny to me :lol: :lol:
daryl
CAJUN 93
Postby PToombs » Fri Jun 29, 2007 6:54 pm
daryl
You are obviously a sick, twisted, preverted individual like myself! :wink: 8)
Postby PToombs » Fri Jun 29, 2007 6:56 pm
I'll have you guys know I had to struggle to keep that clean, but I did it! :roll: :wink:
Postby mhuppertz » Fri Jun 29, 2007 7:45 pm
PToombs wrote:I'll have you guys know I had to struggle to keep that clean, but I did it! :roll: :wink:
I thought it was a masterful job at subtlety. :wink:
mhuppertz
Postby PToombs » Sat Jun 30, 2007 4:30 pm
Thanks! :D
Postby Power Ram Man » Mon Jul 16, 2007 10:21 am
thanks for all the replys can i get a diagram for all this stuff?
92 3/4 Cummins with coverted getrag 5 speed, 4x4 PODS,3200 Gov spring,16cm housing, 4inch exhuast homemade downpipe, water meth,hx35 turbo,5 inch stainless intake with AFE filter, fuel turned up, timing bumped boost,pyro guages, Denny T fuel pin,coolertubz,piston lift pump
Power Ram Man
Postby TWorline » Mon Jul 16, 2007 6:09 pm
Begle1:
I just finished catching up on this thread and am sorry that I was not on the ball. :oops: I live 19 mi. south of Defiance, what were you doing there of all places?
Tim Worline
http://www.CoolerTubz.com/
TWorline
Postby RumbleFish » Mon Jul 16, 2007 7:19 pm
Ditto what Tim said. I'm about 15 miles south of the Ft Wayne airport.
Postby Begle1 » Tue Jul 17, 2007 7:58 am
TWorline wrote:Begle1:
I have family dotted around the region. Grandpa was a Kohout, Grandma was a Herman.
Postby TWorline » Tue Jul 17, 2007 3:21 pm
Well hey it is a small world! If you get back this way let Rumblefish & I know, be glad to get together and talk diesel.
Tim Worline
TWorline
Postby 93 dually » Fri Jul 20, 2007 5:47 pm
yea i turned in mine three turns no run away
1993 d 350 htt turbo 5in stacks high flow intake .butchered fuel pin
93 dually
Postby 1991cummins » Fri Jul 20, 2007 8:45 pm
ok can somebody help me out... ive been to a website called dodge ram.org/tech and it explains how to turn up the pump... i have the star wheel bottomed out the pin turned all the way to the deep side(soon to be grinded :twisted:) and the smoke screw turned about three turns... but still am not sure where the full power screw is... i was contempt that i had turned it up, until here resently and then i read this page and decided that that wasnt it... so pics or a good verbal explanation would help alot...
1991cummins
