Finally getting the twins going..
Re: Finally getting the twins going..
Postby Richie O » Sun Apr 04, 2010 3:24 pm
I had the volume WAY up so I could hear. I was happy till DDDDDRRRRRRRRROOOOOOOOOIIIIIIIDDDD ( droid ) blasted me out of my seat. :D I was like WTF! :lol:
Postby SNOOT » Sun Apr 04, 2010 9:12 pm
lol someone text me when I was filming..lol
1993 W350
SNOOT
Postby SNOOT » Sun Apr 04, 2010 9:26 pm
What do you guys think of putting Super Bee hood scoops on my hood? They will be flat black.
1993 W350
SNOOT
Postby Lucas » Sun Apr 04, 2010 10:59 pm
have to see the scoops on the hood to see if they "work" with the look.
right now ....no
love your truck by the way...............pretty much same as mine besides the color. :P
1992 dodge 350 ic 4x4 dually -auto -410 gears
starwheel bottomed out -40 hp nozzles
pump at runaway.PDR fuel pin.
K+N filter with intake box piped with cold air
Lucas
Postby SNOOT » Mon Apr 05, 2010 6:39 am
Thanx Lucas any one else Love it or hate it?
1993 W350
SNOOT
Postby 1STGENFARMBOY » Mon Apr 05, 2010 11:18 am
I know it,s a little extra money but pick up another hood paint it flat black with the scoops
and make the one over your turbo functional (NOW THAT WOULD SUPER BEE SWEET) HA HA HA :lol:
Postby Swaggs » Mon Apr 05, 2010 12:42 pm
I dont think it would look terrible, some mopar styling.. but everytime i see a pickup with hood scoops I think they are trying too hard.... I like plain and simple.
92 W250 CTD, Getrag, hx35, DiamondEye, Mostly Stock
89 Ramcharger 360/727
'92 W250 CTD, Lifted Sold
'96 2500 CTD Sold
Swaggs
Postby Richie O » Mon Apr 05, 2010 4:09 pm
The original owner of my 89 put a backwards facing non functional scoop on one side of the hood. I like it. One of these days I will take my spare hood and make it a functional scoop. My scoop is what you would see on a old F600 Ford. One of our older Ford fire trucks here in town has the same scoop. ( Its a cherry , low mile late 60's ford. )
Postby SNOOT » Mon Apr 05, 2010 4:24 pm
I have a questions in regards to the turbo set-up.
If you watch the video at the ending I run it up to about 58PSI of boost. From about 52-58# of boost I really dont feel any more power. Its just kinda flat. I really have to get a drive pressure gauge on this thing. My feeling are that anything over 52PSI my drive pressure must be way off preventing the engine to breath.
Example: remember when you could run your old outboard engine WOT and if you did not have the jetting just right you could back off the throttle just a little and the boat would pick up a couple mph.
Looks like I may be installing my waste gate soon.
1993 W350
SNOOT
Postby SChandler » Thu Apr 08, 2010 12:48 pm
Nice job on the twins, looks like they are doing there job. :thumleft: Any plans to dyno it soon?
I vote no on the hoodscoops. I'm not a fan unless they are functional.
Where did you get the dash pods for your gauges and what application are they for?
SChandler
Postby SNOOT » Thu Apr 08, 2010 1:16 pm
SChandler wrote:Nice job on the twins, looks like they are doing there job. :thumleft: Any plans to dyno it soon?
The gauge pod I am using for m boost and pyro is just a cheepo out of summit. The other is a 3 gauge pod that was made for a 1st gen. I will have my cold pipe PSI drive pressure and trans temp in that one. I also have another 2 gauge pod made for 1st gen that mounts on the far left with 2 gauges that will be water temp and engine oil pressure.
When I get the hood scoops I am going to set them on there and snap a photo to see what it looks like. No holes till I get input from others again. I will be putting a 3" hole on each side of the hood if I use the scoops to vent or force cool air into the engine bay.
1993 W350
SNOOT
Postby SNOOT » Sat Apr 24, 2010 9:24 pm
Made 4 pass today at the track!! What a difference twins makes..
Ran a best of 14.13 and a worst of 14.34.
Here is the 14.13 run.
http://www.youtube.com/watch?v=ui_-LqWHLY0
1993 W350
SNOOT
Postby soggy » Sat Apr 24, 2010 9:57 pm
Quite an improvement, what was your 60ft time? Not trying to start anything but it seems like you should be a bit faster for all the stuff you have done.
92 W250 VE Powered
13.31@ 98.92
1993 D350 Tow Rig
soggy
Postby SNOOT » Sat Apr 24, 2010 10:04 pm
soggy wrote:Quite an improvement, what was your 60ft time? Not trying to start anything but it seems like you should be a bit faster for all the stuff you have done.
Agree with you and I know there is allot more on the fuel side I can do. I have two changes to make real soon. 1) Fuel inlet modifications 2) External waste gate . Remember this is a W350..
The fuel inlet changes I want to make will let me turn the pump up further without draining the pump dry. My drive pressure is higher then I want so adding the waste gate is also on the list. Have to get the larger turbo working a little harder.
Here are the details.
60' 1.879
330 5.614
1/8 8.872
mph 1/8 74.81
1/4 14.133
mph 1/4 93.20
And here is the kicker.. I never went over 1,200 on the EGT gauge.. I will be happy running it as high as 1,400 in the 1/4 mile. :mrgreen:
1993 W350
SNOOT
Postby soggy » Sat Apr 24, 2010 10:39 pm
Good deal^^
What psi are you leaving the line at? Sweet truck, hope you whittle those ET's down.
92 W250 VE Powered
13.31@ 98.92
1993 D350 Tow Rig
soggy
