Windshield wipers?
Windshield wipers?
Postby jeff77indy » Sun May 30, 2010 4:37 am
The wipers on my '92 won't go to the park position when the switch is placed in the off position. They work in delay and low/high speeds.
Any ideas?
Thanks
jeff77indy
Re: Windshield wipers?
Postby gobigorgohome » Sun May 30, 2010 9:16 pm
what exactly do they do when switched to the off position? that will help us answer
gobigorgohome
Postby jeff77indy » Mon May 31, 2010 4:00 am
gobigorgohome wrote:what exactly do they do when switched to the off position? that will help us answer
They stop in the position they are at when the switch is turned to off. This is the same in all modes. They do run in delay and in all speeds. But will not go to park just stop when turned off.
Jeff
jeff77indy
Postby Richie O » Mon May 31, 2010 8:10 am
You basically have a busted park in the motor. Not sure if it can be fixed. You may need to replace it. I have had them frig up in a chevy before and the wipers would run with the switch removed. :D
Postby jeff77indy » Mon May 31, 2010 8:38 am
Richie O wrote:You basically have a busted park in the motor. Not sure if it can be fixed. You may need to replace it. I have had them frig up in a chevy before and the wipers would run with the switch removed. :D
Thanks, that was what i figured. I guess I'll be heading to the salvage yard down the road, he pretty much specializes in these old Dodge trucks.
Jeff
jeff77indy
Postby 12valve350 » Wed Jun 02, 2010 5:39 pm
what scrapyard is this?...oh and my intermittent dosent work all the time. gotta love old chit
Six in a row makes 'er go, Eight in a v, theres nothin' too see!
12valve350
Postby jeff77indy » Wed Jun 02, 2010 6:19 pm
12valve350 wrote:what scrapyard is this?...oh and my intermittent dosent work all the time. gotta love old chit
Zeller's at West Fork, Indiana.
My intermittent s work they just stop where ever they're at when you turn them off.
Jeff
jeff77indy
Return to Electrical
