Drive Pressure Gauge
Postby lectro_static » Tue Jun 29, 2010 8:04 pm
Will this work for a drive pressure gauge?
http://www.autometer.com/cat_gaugedetai ... 240&sid=12
I was told I should get one installed, autometer doesnt seem to make a "drive pressure" gauge so since I want my gauges to match Im hoping........ What do I need to know about installing a drive pressure gauge, is it just 6' or 1/4" metal line coiled, a filter of some sort and your good?
weeping head gasket
4" straight pipe
M&H M3 fuel pin
M&H Dynamic Timing Advance
366 spring
Auto Meter EGT and Boost
lectro_static
Re: Drive Pressure Gauge
Postby Douglas » Wed Jun 30, 2010 9:49 am
hey-Hey!!!,
Seems to me what you seek to avoid is delivery of hot exhaust to the sensitive gage and/or line feeding it. Your suggestion of a good length of metal tubing ought to serve quite well.
cheers,
Douglas
1991 D250, 727 and 16cm H1C.
Douglas
Postby oldestof11 » Wed Jun 30, 2010 1:30 pm
Guys take about 1-3ft of copper tubing, make a coil, and attach a plastic line to it.The copper coils help to cool the air before the plastic.
Postby lectro_static » Wed Jun 30, 2010 9:23 pm
Is that gauge going to work for drive pressure? I dont even know what it is supposed to be, think I heard somewhere you want to stay under 70lbs but am really not sure
weeping head gasket
4" straight pipe
M&H M3 fuel pin
366 spring
lectro_static
Postby burnt_servo » Thu Jul 01, 2010 12:44 pm
it measures pressure .
so as long as you can keep the heat out of the guage i can't see why it wouldn't work .
'93 w250 .... stock ...
burnt_servo
Postby rockjeep73 » Fri Jul 02, 2010 11:21 am
Just use another auto meter boost gauge like you already have in your truck.
2000 QCLB 2500 4x4, 12.05 @ 111
89 D-250, In The Graveyard
89 W-250, Mostly Stock
http://www.SHSDiesel.com
rockjeep73
Postby IowaCummins » Fri Jul 02, 2010 3:28 pm
they also throw a little 1/8" gas line fuel filter after the copper to help keep soot out of the gauge. i have also hear of people taking a 1/2" copper pipe about 1 1/2" long with compression fittings that reduce down to 1/8" and fill teh tube with steel wool to collect the soot. thats the way i will do it when my gauges come in
IowaCummins
