Non intercooled injectors What size should I make?
4x.014
1
3%
4x.015
2
5%
4x.016
14
36%
4x.018
13
33%
8x.010
3
8%
8x.012
6
15%
Total votes : 39
Postby jkidd » Wed Jul 21, 2010 12:29 pm
I am checking into getting nozzles made for the guys running 9mm tips. It seems that it does not make sense to pay a $200 core + $50-70 for a 9mm-7mm sleeve... + you have the wrong spray pattern when you are finished!!! Seems you could get more power for less than half the price after set-up/ installation/pop-testing, or even less if you do it yourself. I wanted to know if anyone would be interested in 4x.015, 4x.016 or if I would sell more 8x.010 or something. Stock non-ic is 4x.013. Target pricing would be $200-350 a set for flow matched nozzles
You can choose the 2 favorite sizes. Please vote 2x
jkidd
Re: Non intercooled injectors What size should I make?
Postby BC.livewire » Wed Jul 21, 2010 4:20 pm
now I'm know to this so take what I say knowing that I'm new to cummins
I would stick with a 5 to 6 hole injector
BC.livewire
Postby Richie O » Wed Jul 21, 2010 4:33 pm
BC.livewire wrote:now I'm know to this so take what I say knowing that I'm new to cummins
The stock 4x.013's rip. Nothing wrong with 4 hole sticks. :D
Postby jkidd » Thu Jul 22, 2010 2:52 pm
Still pretty even... Remember this is for the 9mm injectors that come with 4 holes. It may be most cost effective to to the 4 hole, but if there is enough demand the 8 hole would probably offer better MPG.
jkidd
Postby meby » Fri Jul 23, 2010 6:11 am
jkidd wrote:Still pretty even... Remember this is for the 9mm injectors that come with 4 holes. It may be most cost effective to to the 4 hole, but if there is enough demand the 8 hole would probably offer better MPG.
Do a search around here before you go with the 8 hole injector, there have been several threads explaining why they don't work.
-1991 D-250 bone stock
-1997 Civic Hatchback
-Case 530 CK
-Speedex Walking Tractor.
-BCS Walking Tractor
www.ebyfarmsllc.com
meby
Postby jkidd » Fri Jul 23, 2010 8:27 am
Really the size of the hole is less important than the flow. Some times injectors are not accurately labeled as the suggested hole size does not flow what it is supposed to. this would indicate an error in the production process. I will look into the 8 hole nozzle some more by searching
jkidd
Postby jimbo486 » Sun Jul 25, 2010 12:11 pm
stock non-i/c injectors are 4x.012s. just FYI 8)
i think 4x.016s or 4x.018s would make good power even on a stock pump.
'90 D350 LE Cab & Chassis
3200 Spring - M3 Fuel Pin - M&H Timing Spacer - 4x.014's - Piston LP - I/C'd - Fluidampr - 4" Turbo Back - '01 NV5600 - SB Con OFE - 3.54 LS - Autometer Tach - UltraLite II 60psi Boost - UltraLite II Pyro
jimbo486
smoke screw?
Postby JBradley500 » Sun Jul 25, 2010 1:27 pm
i dont have a NON-IC but i do have an opinion.... stock non-ic injectors make good power so i say, go big or go home on the aftermarket ones. thats where id guess the biggest market would be. you can always turn your pump down.
340hp/662tq (8/24/12)
JBradley500
Postby pulltilbroke » Tue Jul 27, 2010 8:13 pm
If I were gonna stick with a N/IC head I'd try a set of 20s
Postby projectworkstock » Tue Jul 27, 2010 8:26 pm
i am definatley interested in a set of 4x18s or possibly a set of 4x20s, what kind of price would there be for a set of nozzles with injector bodies due to the fact that mine are old and leaky
projectworkstock
Postby jkidd » Wed Jul 28, 2010 10:12 am
Looks like the 4 hole are winning. It will probably be 2 months before I can get these finished up.
jkidd
Postby oldcool90 » Wed Jul 28, 2010 5:27 pm
I have and are running in my truck a set of school bus 9mm injectors that are a 5 hole tip the holes look realy close to the same size as my stock non/ic ones.I have a freind that was a bus mechanic and i got them from him.Would like to know more about them if any one knows.Truck sems to run good with them,made357hp on dunbars dyno last year.
oldcool90
Postby huntinguy » Mon Sep 27, 2010 8:14 pm
What would a set of these tips cost?
89 non-I/C W-250, flatbed. 4" turbo back. Ground fuel pin, AFC tuning.
huntinguy
Postby Douglas » Sat Oct 02, 2010 12:52 pm
hey-Hey!!!,
I'd actually like to try a set of 4x .010...but I am not sure it is worth the bill. For performance the 4x .014 looks like a sweet option. However, I am also pretty sure that the smaller ones will do a bit better on fuel economy and that would be far liklier to get my wallet open. Yeah...I am a bit on the fringe side, of a fringe group to begin with so I really don't expect much.
cheers,
Douglas
1991 D250, 727 and 16cm H1C.
Douglas
Postby jkidd » Wed Jul 27, 2011 5:39 pm
Figured I should update this thread. The 9mm nozzles have been difficult to produce. I do have 7 hole 155* nozzles and hope to have 155* 5 hole nozzles at a better price, but they are 7mm.
For those running intercooled 145* I have plenty of 5x.016 and 5x.018 in stock and can add lift. Should have more 5x.014, 5x.013 and 5x.012 in stock shortly.
jkidd
