cheapest place to buy the 15psi lp
Postby rattlebox93 » Thu Aug 12, 2010 11:47 am
i called the case dealer around here and they and they wanted $390 bucks for the 3936320 pump does that sound rite? also what is the current 15psi lp pn thanks dj
rattlebox93
Re: cheapest place to buy the 15psi lp
Postby meby » Thu Aug 12, 2010 2:00 pm
Sounds high. There's a site on the web that has the 15psi lp for under a hundred.
Try this link.
http://www.dieselpartsdirect.com/item_d ... =DS3936320
-1991 D-250 bone stock
-1997 Civic Hatchback
-Case 530 CK
-Speedex Walking Tractor.
-BCS Walking Tractor
www.ebyfarmsllc.com
meby
Postby Richie O » Thu Aug 12, 2010 2:20 pm
Yes the case one is now big money. As far as the under a hundred ones the psi is less then the 15 your after ( or so I have read ). :oops: Cummins has the real deal for around 185 bucks.
Postby dpuckett » Thu Aug 12, 2010 6:46 pm
I have a Delphi piston pump on my 93, and it puts out right at 12psi after a new filter.
DP
Postby Richie O » Thu Aug 12, 2010 6:48 pm
dpuckett wrote:I have a Delphi piston pump on my 93, and it puts out right at 12psi after a new filter.
DP
Nice!! was that one of the cheaper ones?? My case does about 13 or so after the filter.
Postby Mark Nixon » Fri Aug 13, 2010 6:44 am
So, what pressure starts affecting the timing advance in the pump?
I was under the impression that you had to keep the lift pump pressure below 10 pounds.
Postby JBradley500 » Fri Aug 13, 2010 10:30 am
I got mine from tenn. Diesel conversions. It puts out 15psi at wot after filter (fleetguard 1221 I think).
340hp/662tq (8/24/12)
JBradley500
Postby PToombs » Fri Aug 13, 2010 6:13 pm
Mine was only putting out about 12-13 after a mild starvation issue, it was 15 before that. I ran a draw straw and a 1/2" line to the LP and now it's 17-18 after the filter, and shoots to 20 once in a while. There's also a 10 micron filter in the suction side. This is with the stock fuel heater and unmolested small hole in the filter head. I'll get around to correcting that someday, you can't rush these things! :lol:
I was shocked at the difference the big suction line makes. 8)
Postby 1990 » Sat Aug 14, 2010 2:27 pm
Prices? My stock lift pump runs 5 PSI all day, but i haven't turned the fuel screw up yet. I'd like to be ready when i do.
2012 Subaru WRX TP Stage 1 DD
Postby JBradley500 » Sat Aug 14, 2010 3:56 pm
1990 wrote:Prices? My stock lift pump runs 5 PSI all day, but i haven't turned the fuel screw up yet. I'd like to be ready when i do.
the entire kit needed to bolt it right up was 279 dollars when i got mine earlier this year.
you can get info how get ahold of the place i got mine from.
http://www.4btswaps.com/forum/showthrea ... onversions
JBradley500
Postby dpuckett » Sat Aug 14, 2010 8:05 pm
DP
Yes, I think it was $50 with a Buy It Now on ebay, $10 or so to ship. If I had it to do over, I'd skip the $40 Cummins line and just run a few barbed fittings and 3/8 or so line to the IP.
Mark- I dont think it'll affect the overall advance of the injector pump- the curve will be the same, just shifted to the right a little bit with the higher inlet pressure. I still have my stock LP, and a way to test case pressure. Guess when the weather cools a bit (below triple digits temps), I could do some swapping around and get back with y'all.
Low pressure (<4-5psi) can affect the longevity of the injector pump.
Postby kensmachine » Fri Aug 20, 2010 7:01 am
wats the Delpli Part number thanks ken
kensmachine
Postby dpuckett » Fri Aug 20, 2010 5:05 pm
I'll have to look it up- Seems like HFP 702 or something like that. I'm pretty sure of the 702, not sure of the letters.
DP
Postby rattlebox93 » Fri Aug 20, 2010 7:07 pm
hfp702 is rite but my cost on it form napa is $275
rattlebox93
Postby dpuckett » Tue Aug 24, 2010 10:11 am
Got mine from ebay.
