Fuel filter inlet banjo
Postby Douglas » Mon Sep 13, 2010 3:20 am
hey-Hey!!!,
What size is the banjo on the fuel filter inlet? I think it is 12mm( but that is just 'net research ), and I'd like to know for sure. Going to put an electric pump on and use a banjo-to-barb fitting to simplify the process a bit.
cheers,
Douglas
1991 D250, 727 and 16cm H1C.
Douglas
Re: Fuel filter inlet banjo
Postby Remps » Mon Sep 13, 2010 6:05 am
Pretty sure its 13 mm. I drilled mine out to 11/64, and sealed them with the old copper gaskets no prob. I had new gaskets on hand just in case. Drilling them any bigger weakens the bolt too much. Also the bleeder bolt on the fuel filter outlet banjo protrudes into the flow area, so I shortened it as well.
Postby CaptainChrysler » Wed Sep 15, 2010 2:42 pm
The two in the head for the filter and the inlet to the pump are all 12mm x 1.5.
1993 W-350 EXT CAB SRW
GETRAG, DC-1'S, 285'S
370'S, HX40, 5" EXHAUST, BHAF
1989 W-350 SRW
GETRAG/NV273
P-PUMPED, 2.6" S400
WATER-2-AIR IC, SBC DD
CaptainChrysler
Postby Douglas » Thu Sep 16, 2010 3:11 am
CaptainChrysler wrote:The two in the head for the filter and the inlet to the pump are all 12mm x 1.5.
Thanks Captain, that was most helpful. Now it is off to go shopping for the banjo-to-barb and a Holley Black...:)
cheers,
Douglas
Douglas
Postby dpuckett » Sun Sep 19, 2010 4:45 pm
A 1/2" banjo-barb will work just fine by the time you seal it with a washer.
DP
