BAE Headers
BAE Headers
Postby Scout4life » Wed Nov 03, 2010 9:46 pm
i just read this months diesel power. theres an article about a tubular exhaust manifold that looks pretty sweet. called th number th guy said he was all out of stock. just wondering if any of you bought one. its a company out of houston, tx called BAE.
91.5 reg cab W250, NV4500 BD short shifter, Valair 450hp single disk, GDS 60mm, SDX 5X.014s, Denny T stage 2, straight pipe, Spartan locker, warn hubs, GLO 1/2" diff cover
Scout4life
Re: BAE Headers
Postby Scout4life » Thu Nov 04, 2010 10:04 am
got some pics
Scout4life
Re: BAE Headers
Postby ellis93 » Thu Nov 04, 2010 10:13 am
There was a red 1 ton with a header in the mag. Said it was used for towin. I think they'd help spool up but would need something on the outside to keep the heat in.
Re: BAE Headers
Postby PJ 3 » Thu Nov 04, 2010 10:42 am
With the high egt's and thin wall stainless I doubt it would be practical for a daily driver. Kinda on the weak side for my liking but might be a good fix for a track or pull truck. I wonder if they lower your egt's with the design ?
Pete
1992 W250
PJ 3
Re: BAE Headers
Postby oldestof11 » Thu Nov 04, 2010 2:22 pm
You will only need it if you are pushing more than 4o psi of boost and have around 500hp on the low end.
By going to a tubular manifold like that, you lose both velocity and heat of the exhaust gases, both essential to making a turbo work. So once this is added, more lag and less boost with the same, if not higher, EGT's.
Re: BAE Headers
Postby JQmile » Thu Nov 04, 2010 7:55 pm
Headers will drop EGT anywhere from 100 to 200 degrees from what I've seen, but I'm not exactly sure why. Power is usually up a little but not much (maybe 5-10hp) but you do lose some exhaust pressure, although not near enough to keep anything but 70+mm turbos from spooling. If I were ever to get one, it would be mainly cause they look badass. :D
JQmile
Re: BAE Headers
Postby 1STGENFARMBOY » Fri Nov 05, 2010 7:16 am
If i could afford one, (ya know beeing a poor 1st genner) and i knew for shure i would'nt loose any performance
i WOULD GET ONE because of the mean look also.
Dar
Re: BAE Headers
Postby BILTIT » Fri Nov 05, 2010 8:37 am
JQmile wrote:Headers will drop EGT anywhere from 100 to 200 degrees from what I've seen, but I'm not exactly sure why. Power is usually up a little but not much (maybe 5-10hp) but you do lose some exhaust pressure, although not near enough to keep anything but 70+mm turbos from spooling. If I were ever to get one, it would be mainly cause they look badass. :D
They drop heat because they transfer heat quickly to the surrounding air due to the thin wall material. I think if you wrapped them with high temp header wrap you would keep the heat and performance.
Anybody know the cost of them?
Derek B.
BILTIT
Re: BAE Headers
Postby 1STGENFARMBOY » Fri Nov 05, 2010 9:23 am
I was thinkin $500-600 but not shure, JQ will tell ya nobody here can afford it anyhow. :shock: :shock:
just messin with ya man.
Re: BAE Headers
Postby Scout4life » Fri Nov 05, 2010 11:07 am
The guy quoted me $950 and another $200 for ceramic coating. he also said they are .120 wall tubing, so theyre not real thin walled. also said they weight 30 pounds.
Scout4life
Re: BAE Headers
Postby lectro_static » Fri Nov 05, 2010 11:41 am
If you get a set get the coated and then wrap them with header tape, that will hold the heat in for you
weeping head gasket
4" straight pipe
M&H M3 fuel pin
M&H Dynamic Timing Advance
366 spring
Auto Meter EGT and Boost
lectro_static
Re: BAE Headers
Postby 1STGENFARMBOY » Fri Nov 05, 2010 12:35 pm
WOW sorry scout i saw one somewhere that was not pollished, i guess that was the one for 500
Re: BAE Headers
Postby oldestof11 » Fri Nov 05, 2010 3:25 pm
Now, will retaining too much heat (ceramic and wrap) cause it to warp and crack the weld or pipe? :?:
Re: BAE Headers
Postby Scout4life » Fri Nov 05, 2010 9:44 pm
I have read that wrapping ANY header will eventually lead to stress cracks, because the wrap retains so much heat it fatigues the metal, even the inconel and titanium exhaust. wrapping voids the warranties on the few companies that offer them for their headers.
Scout4life
Re: BAE Headers
Postby BILTIT » Fri Nov 05, 2010 10:17 pm
Scout4life wrote:I have read that wrapping ANY header will eventually lead to stress cracks, because the wrap retains so much heat it fatigues the metal, even the inconel and titanium exhaust. wrapping voids the warranties on the few companies that offer them for their headers.
True, all depends how long it takes.
A good ceramic coat would probably be sufficiant.
Derek B.
BILTIT
