Help with my plan...
Re: Help with my plan...
Postby rokit » Mon Dec 06, 2010 8:58 pm
I would get one of DennyT's pins and install a valet switch for towing
i could see using a valet to shut off the afc and be able to control some more fuel
Um...newb here :oops: . I admittedly need to gain a better understanding of how the VE pump works (is there a tutorial somwhere?). In the meantime, what's an AFC and what about it would I be changing with the flip of a switch?
I'm hearing a lot of recommendation here for a S300 in 62/71/14 flavor. Any other suggestions out there (just for thought...)?
rokit
Postby PJ 3 » Tue Dec 07, 2010 3:59 am
This link might give you a better understanding of the VE Pump....... :arrow: http://dodgeram.org/tech/dsl/more_power/Power_ve.htm
Pete
1992 W250
PJ 3
Postby lectro_static » Tue Dec 07, 2010 9:28 pm
I am still pushing the he351ve that I have made a HUGE difference in power, (still need to dyno it) and they are CHEAP just takes a bit of fooling with to get the VGT set where you like it
weeping head gasket
4" straight pipe
M&H M3 fuel pin
M&H Dynamic Timing Advance
366 spring
Auto Meter EGT and Boost
lectro_static
Postby Douglas » Fri Dec 10, 2010 5:39 pm
hey-Hey!!!,
What about an HX40 with a 16cm housing? IC'd ov course.
cheers,
Douglas
1991 D250, 727 and 16cm H1C.
Douglas
Users browsing this forum: No registered users and 70 guests
