60mm turbo upgrade
60mm turbo upgrade
Postby 91bluecummins » Mon Jan 10, 2011 7:18 pm
is the 60mm turbo upgrade from gds or htt better can yall share with me your experiences with this up grade and is it much of a up grade for the cost and if anybody could post a pic with theres on it
92 cummins W250 extenged cab (The Goat) project truck
90 cummins W350 single cab dually flat bed 5 speed, he351ve 62mm
1959 chevy Apache 4bt cummins 4 speed
91bluecummins
Re: 60mm turbo upgrade
Postby ellis93 » Mon Jan 10, 2011 7:33 pm
My experience was that if the turbo bushings are not tight the new inducer fins will hit the housing.
Was it worth it? Yes. Would I do it again? Yes I would. I like it. Mine seems to push a lot of air and sounds off to boot.
Postby 92 D/UNIT » Tue Jan 11, 2011 6:26 am
I always deal with GDS. there pricing and customer service is better(in my opinion). as far as the 60mm wheels and housings its like comparing apples to apples.. this is a great performance upgrade that doesnt cost an arm and a leg...
388/886
92 D/UNIT
Postby 1STGENFARMBOY » Tue Jan 11, 2011 8:04 am
I also have a GDS 60mm along with a 16cm housing and i'm very satisfied with the performance and the cooling,
but others have the same set up with monster injectors and the 60mm won't keep it cool.
Darwin
Postby PToombs » Tue Jan 11, 2011 5:55 pm
I don't have monster injectors, just big ones (370's), and it's not quite enough. Temps get up to about 1200* at 3k rpms and then it's just toast after that.
Postby ellis93 » Tue Jan 11, 2011 6:27 pm
Mr Toombs under what conditions was your truck under. Hard acceleration, towing or just riding.
Postby 91bluecummins » Tue Jan 11, 2011 7:13 pm
thanks yall it will be my next upgrade probely from htt ,i really would like to see the diference in a pic or something
91bluecummins
Postby Richie O » Tue Jan 11, 2011 7:43 pm
I would go with the GDS not HTT as its way cheaper. The Htt is suposed to be a better unit, but not enough to make it twice as expensive. If your going to spend 4 hundred bucks upgrading your H1C, just hold off and buy a brand new Super HX40 for around 850 or a S300 Borge warner 57mm unit for about the same. Atleast then you get a 4 inch exhaust outlet. I did the gds on my 93 but I already had a 16 cm housing so it was cheap for me and has got me by for a couple of years, but I will be buying a new turbo soon to replace it. The H1C then will be put on my 92 to get rid of the 21 cm stock bog monster.
Postby 1STGENFARMBOY » Tue Jan 11, 2011 7:49 pm
I agree with Richie, I don't think you will see a big change unless you put a 16cm or smaller housing,
so by the time you get both parts an HX40 or an S300 would be a better bang for the buck.
Dar
Postby PToombs » Wed Jan 12, 2011 6:57 pm
Ellis, that's with my foot pushed right on down as far as I can, unloaded. Valet switch on. Towing was even more fun, I had about 9k on including the trailer and any hill the pyro went up faster than the speedo came down. :lol: I had the valet on for that too, it was better with it off, but not much.
Postby ellis93 » Wed Jan 12, 2011 7:21 pm
Cool. That's what I was curious about. Thanks.
