Anyone interested in
Postby lectro_static » Fri Jan 21, 2011 3:42 pm
I have a spring shop across the parking lot from me and have been talking to them about making a spring for 2nd gen lift pumps that would lower the pressure to about 15psi. I was wondering if anyone else would be interested in doing that. The benefit of the 2nd gen is appx 25% more volume compared to the LPLP that most are using now.
The price will depend on how many they make so the more people we can get in on this the cheaper it will be.
Thoughts??
weeping head gasket
4" straight pipe
M&H M3 fuel pin
M&H Dynamic Timing Advance
366 spring
Auto Meter EGT and Boost
lectro_static
Re: Anyone interested in
Postby PRINCETON_JAKE » Fri Jan 21, 2011 5:32 pm
If there reasonable i would be interested in a dozen or so, you can get good used second gen pumps for nothing since everyone upgrades to electric on 2nd gens.
1992 cummins, 2wd, A518, WH1c, 60mm,12cm housing, fuel screws maxxed, fuel pin turned and ground, 3200rpm spring, big Amsoil air filter, 4" stack, timming bumped, piston lift pump, Bosch 190's, 18" Maxxi Hulk rims, and Nitto Terra Grapplers.
PRINCETON_JAKE
Postby The_Head » Fri Jan 21, 2011 6:43 pm
Yeah, I'd be interested.
The_Head
Postby moparman87 » Fri Jan 21, 2011 10:33 pm
I would be interested in a couple depending on price and quality.
90 1 ton 4X4 Auto. Dually,P pumped ( RIP VE )
moparman87
Postby jeff77indy » Sat Jan 22, 2011 7:46 am
May be according to price.
jeff77indy
Postby cougar » Sat Jan 22, 2011 9:40 am
Darn, and I just bought a low pressure pump.
01 2500 "the work truck".
cougar
Postby JBradley500 » Sat Jan 22, 2011 9:53 am
cougar wrote:Darn, and I just bought a low pressure pump.
Just buy a high pressure pump from geno's and mix the parts together. That's what I did lol.
340hp/662tq (8/24/12)
JBradley500
Postby JBradley500 » Sat Jan 22, 2011 9:54 am
Lecto---One thing. My high pressure pump inlet is different than the low pressure pump. Youd need to find a fitting to adapt.
low pressure is on the left, high pressure is on the right.
JBradley500
Postby BC847 » Sat Jan 22, 2011 10:59 am
Just swap the entire piece from the LP body to the HP body. ;)
Postby JBradley500 » Sat Jan 22, 2011 11:00 am
Thats what i did... but it wont work if you dont have the LPLP also. If you have a 2nd gen pump and a custom spring, the factory fitting is too small for the lift pump.
JBradley500
Postby PToombs » Sat Jan 22, 2011 1:28 pm
Heaven forbid you have to go to the hardware store and get a pipe bushing...... :roll:
Postby JBradley500 » Sat Jan 22, 2011 1:48 pm
PToombs wrote:Heaven forbid you have to go to the hardware store and get a pipe bushing...... :roll:
Get off your high horse. I'm showing people what parts come with the lift pumps.
JBradley500
Postby cougar » Sat Jan 22, 2011 2:03 pm
JBradley500 wrote:Lecto---One thing. My high pressure pump inlet is different than the low pressure pump. Youd need to find a fitting to adapt.
That would be easy because my 91 uses a hose barb fitting instead of the disconnect thingie my 92 has.
cougar
Postby cougar » Sat Jan 22, 2011 2:15 pm
Hum, just a thought. Would there be any advantage to drilling up the smaller inlet in the interim? I have to replace my lift pump and can't hold off till later.
cougar
Postby PToombs » Sat Jan 22, 2011 6:17 pm
JBradley500 wrote:Get off your high horse. I'm showing people what parts come with the lift pumps.
What everrrrrrrr! :roll: You made it sound like it was a big deal that the holes were different sizes.
