BRAKES...HELP!!!!
Re: BRAKES...HELP!!!!
Postby Ironforger » Sun Feb 20, 2011 8:42 pm
PToombs wrote:
If you replace the brake line from the front, no adapters are needed. The line will screw right into the hose connection. That's what I did on mine.
Toombs: did you use a pre-formed brake line? Or did you bend up your own?
I checked all of my flare nut fittings today, only a couple of them turn free. The rest are stuck to the steel line, which are pretty damn rusty overall. So, I'm going to do the right thing and replace all of my steel brake lines. There is a guy near me who makes replica brake lines bent up exactly to match your existing lines. Only thing is you gotta bring him all of the old ones. Looks to me like I gotta drop the fuel tank though to replace the front to rear line, as I can't get to the brake line clips which are bolted to the frame up behind the fuel tank.
So anyway toombs, when you replaced the brake line that goes from front all the way to the abs module in the back, instead of going to the abs module, did you just shorten the brake line and bend it up so it fits into the hose where it mounts to that bracket? (bracket bolted to the frame, rubber hose goes from the bracket to the axle where it splits off in a brass Y block to each respective wheel cylinder, Y block has the differential vent coming out of it). Also, did you drop the fuel tank?
Thanks!
FOR SALE --> 1990 W250 5sp reg cab. 21 mpg. Aprx 145k. (odo broke last year) Fuel screw. KDP killed. Solid floors, rockers & cab corners. Pm me.
FOR SALE --> 1995 Izuzu NPR 16ft Morgan body/side door. 160k. 80 k on reb auto trans. 1 ton lift gate. Pm me.
2002 3500 6 sp Qaud cab 2 wd. 202k <-- One badass truck!
1999 VW beetle tdi. PP520 injec. Rocketchip st. 3. 45 mpg. 260k
Ironforger
Postby PToombs » Mon Feb 21, 2011 7:24 pm
No, yes, no, no, yes, yes, maybe! :lol:
I think you got all the answers from your pm, but, I bent my own, I ran the line direct to the hose, I covered the end of the line and shoved it thru behind the tank. Later on I dropped the tank to repair the frame that almost wasn't there any more, and put in the plastic pipe at that time. Right now nothing goes thru the plastic, but that might change shortly.
Postby ivel_86 » Tue Feb 22, 2011 1:00 pm
funniest thing about it was all I wanted to know was what the part looked like. I did not however want to start a debate because its useless. Its is as productive as argueing dodge vs chevy vs ford. Who cares someone else will always disagree. But those that did help (telling me what were and how) THANK YOU very much.
US ARMY SGT
OIF 08-09
'93 W250, 4in Sky Lacker 35in Kelly Safari, Pump turned up, Fuel Pin ground, Pyro and Boost gauges, Straight piped, Home made air cleaner assembly.
ivel_86
Postby PToombs » Tue Feb 22, 2011 6:58 pm
ivel_86 wrote:.. Its is as productive as argueing dodge vs chevy vs ford. Who cares someone else will always disagree.
You got that right! :lol: Some people have never had problems with theirs, they work perfectly. Alot don't. That's the way it is, so you do what you have to do, and move on.
Glad you got it working. 8)
Postby slow_90firebird » Sat Feb 26, 2011 4:59 pm
Why pay someone to bend brake lines just use your 2 thumbs thats how i do it.
And my buddy uses the black steel compression fittings from NAPA. The guy at the store said they are legal (in ct). He said the brass ones from depot or lowes are illegal. Works great tho.
slow_90firebird
Postby PToombs » Sat Feb 26, 2011 6:54 pm
This guy at the store, is he the same one that when you say you need a 30 amp fuse he wants to know the year and model car? :roll:
Postby ellis93 » Sat Feb 26, 2011 7:24 pm
Mr Toombs, you know that the parts guys know all :roll:
Postby PToombs » Sat Feb 26, 2011 7:29 pm
Yup, his computer told him so! ;)
Postby Richie O » Sat Feb 26, 2011 7:45 pm
HEY!, I was a parts guy for a couple years. Hated talking on the phone all day and having no voice at the end of every day. Pay was bad, bad, bad. Did I say the pay was bad? :D To many drones trying to buy parts for there car and having no idea what they had for engines or anything else. Then they were the ones pissed when the parts for the 4 cyl did not fit there V8. :roll:
Postby ellis93 » Sat Feb 26, 2011 8:24 pm
Well did you ever suggest a compression union on a brake line. :P.
Postby Richie O » Sat Feb 26, 2011 8:31 pm
ellis93 wrote:Well did you ever suggest a compression union on a brake line. :P.
I had a guy come in for some rubber fuel line and some clamps. I said no prob, what you fixin? He said he wanted to run rubber fuel line with hose clamps for brake lines so he could get a sticker. :shock: I didn't sell him any rubber line. :lol:
Postby ivel_86 » Mon Mar 28, 2011 6:26 am
Well guys I ended up just running a brand new line from the front to back. I bypassed the anti-lock brakes and wow. What a diffrence. Now I do need to spend a little time adjusting the rear brakes but man does it ever stop better. Thanks for all that replied.
US ARMY SGT
OIF 08-09
ivel_86
