First Attempt At Twins...
Re: First Attempt At Twins...
Postby AHineman » Thu Mar 03, 2011 9:12 pm
Just try to keep up. ;)
But til you build your twins Levi this is all you'll see. :lol: :lol: :lol: :lol:
http://i809.photobucket.com/albums/zz16 ... CN0022.jpg
Postby DLittle » Thu Mar 03, 2011 9:33 pm
Looking Good 8)
Dana
1992 W250 auto, 290 k, stock for now SOLD
1973 W100 SWB, D70,D60, 5.9 Twin Turbo SOLD
1993 W250 193k, Auto, TOTALED 10/30/2009
DLittle
Postby soggy » Thu Mar 03, 2011 10:03 pm
Looks nice, when are you hitting the rollers?
92 W250 VE Powered
13.31@ 98.92
1993 D350 Tow Rig
soggy
Postby AHineman » Fri Mar 04, 2011 5:43 am
Thanks for the complements guys. Plans are to try to dyno on June 4 at the Buckeye Nationals in Hebron, Ohio. I'd like to have a better fuel system by then, but don't know if that'll happen or not.
Postby Tacoclaw » Fri Mar 04, 2011 7:39 am
AHineman wrote:Just try to keep up. ;)
I hope you had to take time out of your day to go get that picture. :P
Maybe you could start a tire fire behind it and retake the picture to give me a more accurate idea.
Postby 1990 » Fri Mar 04, 2011 4:27 pm
Looks sweet!
2012 Subaru WRX TP Stage 1 DD
Postby AHineman » Sat Mar 05, 2011 10:56 pm
Postby JustinRhodes » Sun Mar 06, 2011 6:22 am
AHineman wrote:http://www.youtube.com/watch?v=O9yb6BR-7co
http://www.youtube.com/watch?v=4DFN5Brd-L0
A couple of cell phone videos of my boost gauge. 8)
that thing is insane :shock:
JustinRhodes
Postby thumpertrev » Sun Mar 06, 2011 10:08 am
Any thoughts about something like this? Maybe wired to a switch on the throttle and a relay?
http://autospeed.com/cms/title_The-AllE ... ticle.html
1994 Ford crew cab dually.Turbos-WH1C over a TV8102,3" charge piping,largest aluminum I/C I could fit,5" turbo back,SDX11 5x12,mild head porting,ARP studs,Throttle mod,ground pin,366 spring, fuel screw bottomed(no runaway),A518 with low stall converter.
thumpertrev
Postby AHineman » Sun Mar 06, 2011 8:26 pm
Back when I thought a blowoff valve might help, I thought about a Normally Closed switch under the gas pedal and a hobbs switch plumbed into the manifold and set for (lets just say) 50 psi. These two switches would be wired in series. If you had the gas pedal on the floor, the NC switch would not be made and no power to the blowoff valve. If you drive around at partial throttle, the switch under the pedal would be made, but you would be at less than the 50 psi it would take to close your hobbs switch. But if you were running it hard and lifted off the throttle at above 50 psi...both switches would be closed and the blowoff valve would open. No reason to do all this work though because everyone I've ever talked to about this says the blowoff valve won't help the problem of killing it when lifting too fast. Just got to drive a little different.
Postby ahale2772 » Mon Mar 07, 2011 4:12 am
I'd say the only reason that may not work is because it probably would only take one compression stroke to shove air up the injectors, and you would have to be mighty quick to beat that one compression event (one about every .034 of a second at 3500 rpm)
Postby thumpertrev » Mon Mar 07, 2011 1:37 pm
So then where's the happy zone? 40, 45, 50psi? Anyone know? Im building twins for towing and would adjust for MWPWS (max wife psi without stall) :roll: as this would only result in my wife calling me the first time she borrows it.
thumpertrev
Postby Tacoclaw » Mon Mar 07, 2011 1:42 pm
I run about 40-45 on a single and haven't had any stalling problems. I have a pretty bad habit of letting off quickly all the time too. :oops:
Postby gobigorgohome » Sat Mar 19, 2011 5:43 pm
i really wanna put a set of twins in my trk this summer and i dont have a problem fabbin up hot and cold pipe but i wanna know how ppl are supporting the bottom trubo. i have seen a few theings but nothin with good pixs
gobigorgohome
Postby AHineman » Sat Mar 19, 2011 7:34 pm
gobigorgohome wrote:i wanna know how ppl are supporting the bottom trubo.
Here are some better pics of my brace.
My primary brace bolts to the top of the center section of the turbo and to the motor mount. My primary is low, so by bolting it to the top, I had more room for my drain and I could install/remove the brace with the turbo on the truck much easier. I made it out of angle iron and 1/4" plate.
