Super B or Super B special?
Postby slingshot » Tue Mar 29, 2011 6:46 pm
I just ordered my 5X16 vco's and now I need to order my turbo. Need some help deciding on a turbo for some towing lots of playing and streetable power. 93 W250.
1993 W250 5speed.
slingshot
Re: Super B or Super B special?
Postby Richie O » Tue Mar 29, 2011 6:53 pm
Super B special will cool more power. I have 300 at the wheels in my 89 with a 57mm ( super b size ) S300. Its about the limit for that charger. It gets to 1400.
Postby slingshot » Tue Mar 29, 2011 7:08 pm
Richie O wrote:Super B special will cool more power. I have 300 at the wheels in my 89 with a 57mm ( super b size ) S300. Its about the limit for that charger. It gets to 1400.
Yeah, Im not sure that the special is right for me either though. I dont want a laggy turbo, nor do I want a ton of heat.
Anyone run a special on a VE motor with a comparable size injector?
1993 W250 5speed.
slingshot
Postby Richie O » Tue Mar 29, 2011 7:20 pm
Check for sure, but I think the enty level Super B Special is a 62/71/14. You can also go with a 64mm and a 66mm wheel, but I would not go above the 62 model. I would also go with the 14cm (.80 ar ) housing. If you keep your timing on the stockish side, spool should be pretty good. The more you advance the timing, the slower the spool.
Postby AHineman » Wed Mar 30, 2011 2:03 pm
The super b special is a 64/71/14.
Postby Richie O » Wed Mar 30, 2011 5:00 pm
It appears I have got them mixed up with some of the Industrial Injection " Super Phat Shafts ". :oops: O well, so many sizes to choose from.
Postby slingshot » Wed Mar 30, 2011 6:13 pm
So, what are everyones recommendations for my set up? Im afraid that the special will be too much turbo and the super b wont be enough.
1993 W250 5speed.
slingshot
Postby Richie O » Wed Mar 30, 2011 6:25 pm
Well, whats you budget? Turbos can get pretty pricey.
Postby fatty » Wed Mar 30, 2011 7:16 pm
I think you'll be fine with the special. If it's too laggy for you a cam will help the spoolup.
Postby slingshot » Thu Mar 31, 2011 4:00 am
Richie O wrote:Well, whats you budget? Turbos can get pretty pricey.
I would like to stay under $1800
1993 W250 5speed.
slingshot
Postby Richie O » Thu Mar 31, 2011 9:01 am
I would look at Industrial Injection then. They have lots of options for that price and a little under. http://www.industrialinjection.com/id34.html
Postby dazedandconfused » Thu Mar 31, 2011 2:42 pm
Check out forced inductions as well for good prices on turbos.
http://www.forcedinductions.com/productsborgwarner.htm
