by cumminsbo87 » Fri Jun 10, 2011 2:04 pm
i dont think so... i could probley made something similar to the rotted piece, but i figured it had to be just right or the window wouldnt work good. Actually for the past year i had to help it up. Right now if i touch the button the window just falls down in the door, i then can manually pull it up and put the wheels (at the end of the lift arms) under it to hold it in the up position. ALL this happend because the weatherstripping is gone tho! needless to say im putting new on if i get the damn window fixed.
'92 w250 reg cab 4x4, 5spd 188k, denny t stage 2, fuel screw, smoke screw, afc tweaked, 6 inch stack 3.55's
