No power
No power
Postby dazedandconfused » Mon Jun 20, 2011 4:52 pm
I posted this in my thread project ugly duckling detailed. If someone could copy and paste that over here I'd really appreciate it. Short of it is I have no power to anything but the 4 way flashers. It's all 93 wiring harness. Any ideas?
Andy
Re: No power
Postby Richie O » Mon Jun 20, 2011 5:11 pm
Here ya go.
dazedandconfused wrote:Ok so I hit a wall tonight. I've changed all the wiring harness in the truck to the 93 harness. I threw the steering colum in tonight to see if anything worked but just left it laying down on the seat. The dash is still loose laying in the truck as well. So I make sure everything is hooked up and attach the battery. Turn the key and nothing. The only thing I don't have on it is the ground from the engine block to the frame. I checked the fuses with my multi meter and nothing. No headlights, no movement of any gauges nothing. The only thing that works is the 4 way flashers. Anybody got any ideas? There is an orange wire under the hood that I believe had a fusable link in it that's gone so I jumped the wires. Was agrevated so called it quits for the night. Everything is pluged in. The computer isn't mounted to the fender and I didn't put the abs box in it. Someone give me an idea.
Re: No power
Postby PToombs » Mon Jun 20, 2011 5:12 pm
I copied it over for ya.
1983 Dodge D150 2x4 with 93 Cummins/518 Auto.
Re: No power
Postby Richie O » Mon Jun 20, 2011 5:13 pm
FAIL :P
Re: No power
Postby PToombs » Mon Jun 20, 2011 5:13 pm
Richie strikes again! :lol:
Did you hook up the grounds under the dash?
Re: No power
Postby dazedandconfused » Mon Jun 20, 2011 5:20 pm
Thanks guys for copying it my phone won't let me do that. I didn't see any grounds under the dash. I was wondering if maybe it grounded threw the dash mounts. It's gotta be something simple I'm missing tonight. Been agrevated messinh with it while the neighbors worthless mut was trying to chew threw the fence to get me.
Re: No power
Postby dazedandconfused » Mon Jun 20, 2011 6:24 pm
Ok I went back out and don't see any grounds under the dash. I bolted the dash in and the steering colum and I still have nothing but flashers. Nothing else works anywhere.
Re: No power
Postby ellis93 » Mon Jun 20, 2011 6:29 pm
Maybe The big back wire that powers the Y shaped block that feeds the fuse links. Looks like my truck has a barrel connector in that wire, might be there.
Re: No power
Postby dazedandconfused » Mon Jun 20, 2011 6:33 pm
I'll have to look tomorrow since it's almost dark out. I'm not getting any power to the fuse box it appears from my quick probe of the fuses. Leads me to believe there is an issue in the bulkhead plug or before.
Re: No power
Postby oldestof11 » Mon Jun 20, 2011 6:53 pm
When I first saw the title, I thought "needs bigger injectors/turbo".
Other than that, I am of no help. :bom:
Re: No power
Postby dazedandconfused » Tue Jun 21, 2011 6:56 am
Lol I'm gonna mess with it when I get home. Take a little closer look at everything in the engine bay.
Re: No power
Postby Mark Nixon » Tue Jun 21, 2011 9:40 am
Got the connector at the firewall all squared and tightened down correctly?
There are wiring grounds at the core support and behind the head, also.
Under the dash there's a gold irridite plate that's attached to the dash frame, attached to it are wiring grounds.
Make sure your dash is tight. :D
Pull on the fusible links, anything that stretches is burned.
Re: No power
Postby dazedandconfused » Tue Jun 21, 2011 1:13 pm
Well of course it started storming soon as I pulled in the driveway. If it stops raining I'll do some searching. The grounds are on the core support but I need to double check the ones on the cab.
Re: No power
Postby Tacoclaw » Tue Jun 21, 2011 2:46 pm
Mark Nixon wrote:Under the dash there's a gold irridite plate
No wonder Mark gets so rich scrapping these trucks.
Secret's out now. :lol:
Re: No power
Postby dazedandconfused » Tue Jun 21, 2011 2:58 pm
Well fighting rain drops I went out and looked at a few things. Grounds weren't attached at fire wall so attached them and still nothing. Pulled bulkhead plug again and started testing for voltage. I grounded at the battery and probed each pin. Only one pin had power at all and it was 12Vs.
This is that Orange wire that was unhooked when I put it back it. This wire was just twisted together before.
Return to Electrical
