No Radio or Dome light
Postby collegekid » Sat Jul 30, 2011 2:00 pm
I opened the door last night on the truck and I didnt have a dome light, I figured the bulb went out, but when I turned the truck on, I had no radio...the lights on the radio are on, but theres no clock or sound when I turn it on.....I checked the fuses, and the radio fuse was not blown, but the dome light was, so I replaced it and as I put the fuse in it popped, anyone have ideas are where to start troubleshooting
oh yea, the light over the a/c controls with the switch doesnt work either
collegekid
Re: No Radio or Dome light
Postby Hansen01 » Sat Jul 30, 2011 2:37 pm
hehe mine did that for the LONGEST time and i had noo idea why it was doin that looked everywhere, and then one day it just kept working and hasnt quit since :D sorry im of no help but im glad im not the only one that has issues like these :?
Under construction...
Hansen01
Postby collegekid » Sat Jul 30, 2011 2:49 pm
dangit hansen, I thought you woulda had the answer
collegekid
Postby Hansen01 » Sat Jul 30, 2011 3:27 pm
nope, i try tho lol :scratch: it did it for about a month and then one day it jus quit blowing fuses, go over a bunch of bumps real fast and then try puttin a fuse in it ;) lol im sure someone will have an answer to this problem, then maybe i can actually check mine lol
Hansen01
Postby BobS » Sat Jul 30, 2011 4:29 pm
Look on the drivers side inner fender next to the grid heater relays for a round connector #12 or #14 wire size that is corroded. It's round and a single wire plugs into it. It corrodes from the inside out until it looses contact, then the radio quits etc.
BobS
91.5 W250 NV4500 Conversion
89 D350 Stock
BobS
Postby collegekid » Sat Jul 30, 2011 5:28 pm
Bob, I checked all the wires and fusible links by the grid heater, none of them seemed to be split, is there a particular one that needs a light tester put on it
collegekid
Postby collegekid » Sat Jul 30, 2011 6:14 pm
Could I have cut through a wire when I drilled through the floor to install the seats.....it appears that the pink wire leaves the fuse panel and goes to the light above the temp controls, then from there I dont know which way it goes, those of you who have gutted a truck may know... :?
Cigar Lighter is out too
collegekid
Postby BobS » Sun Jul 31, 2011 3:36 am
The whitish one with the jumper lead still temporarily installed back in 2005:
BobS
89 D350 Stock
BobS
Postby collegekid » Sun Jul 31, 2011 1:20 pm
All of my fusible links have power in them, and the fuse panel is getting juice, but once it leaves there, it blows the cigar plug, cargo lamp, and dome light fuses, radio fuse doesnt blow.....wtf is going on, im no electrician, but im getting frustrated with this problem, I have the cluster out anyone with ideas on where to go next
collegekid
Postby dazedandconfused » Sun Jul 31, 2011 2:53 pm
This is the Harness in my 83/93 that runs to the rear dome, cargo light and speakers. Try unplugging it and seeing if you stop blowing fuses. I believe the green plug is the speakers.
Postby collegekid » Sun Jul 31, 2011 3:09 pm
Dazed, undid it and it quit blowing fuses, traced the wire back, (had to pull up the carpet) and the wires were worn through right before the split to the seatbelt plug, cut and spliced, everything (including the radio) work properly now, thanks bud
collegekid
Postby dazedandconfused » Sun Jul 31, 2011 3:17 pm
Not a problem. I figured that would be your issue.
Andy
Postby Hansen01 » Sun Jul 31, 2011 7:15 pm
well at least i have some idea of where to look if this happens to mine again :D
this site is so handy :mrgreen:
Hansen01
Postby Douglas » Sat Oct 01, 2011 9:46 am
hey-Hey!!!,
I am having the same sort of issue; no radio or interior lights. Got power at all the fuses, and none of them are blown. I just hung two new fenders and now the radio doesn't work. I will check those connectors in the pic in case they've got some issues down stream...I am thoroughly stumped on this one.
cheers,
Douglas
1991 D250, 727 and 16cm H1C.
Douglas
Postby collegekid » Tue Oct 04, 2011 6:11 pm
Ya, check under the hood at the fusibles, mine had worn through under the carpet by the driver side seat and shut down power to both, its typically the obvious with these trucks
collegekid
Return to Electrical
