full power fueling screw
Re: full power fueling screw
Postby Hansen01 » Wed Aug 03, 2011 9:24 pm
maybe your injectors are gettin screwy? hmm some else might know on here
Under construction...
Hansen01
Postby DieselLam » Fri Aug 05, 2011 8:09 am
No injectors are good. Air bound pump was the problem. I was thinking about it because overtime I changed record filters the genset would run like that so its running good now. Althouth when I give it fuel it seems to take a min to drop down again. Ill have to take a look at it again.
1993 D-250 straight pipe, PDR intake, Pump tweaked. KDP DDP fuel pin.
DieselLam
Postby Hansen01 » Fri Aug 05, 2011 4:30 pm
if the rpms hang turn the full power screw down 1/8 turn
Hansen01
Postby SEAK » Wed Aug 10, 2011 12:16 pm
What is an air bound pump????? I may be having this problem. See my other thread about bleeding after pump top removal. My truck will run fine for a few minutes and then die. Good stream out of the injectors and then sometimes nothing out of some injectors - when cracked.
Another thing with a dennyt2 mine hit runaway before bottoming out and now I bottomed it out and no runaway after putting stock pin back in. 89 nonic
SEAK
