Narrower belt?
Narrower belt?
Postby Diesel » Sun Aug 14, 2011 6:45 am
Is there a 7 rib that would work on my IC 91? Or even 6 rib?
1991.5 D250 Intercooled A518
Diesel
Re: Narrower belt?
Postby Hansen01 » Sun Aug 14, 2011 8:24 am
how come you want a narrower belt?
Under construction...
Hansen01
Re: Narrower belt?
Postby Diesel » Sun Aug 14, 2011 11:34 am
Something is screwy with my AC compressor so it cuts the last rib off my stock 8 rib belts.
Diesel
Re: Narrower belt?
Postby PToombs » Sun Aug 14, 2011 6:12 pm
Check the belt tensioner. They wear out the plastic bushing inside and twist, shooting the belt out a little on the next pulley, the AC compressor. If the belt is running on the edge of the tensioner pulley, it's junk.
Re: Narrower belt?
Postby BC847 » Sun Aug 14, 2011 7:05 pm
PToombs wrote:Check the belt tensioner. They wear out the plastic bushing inside and twist, shooting the belt out a little on the next pulley, the AC compressor. If the belt is running on the edge of the tensioner pulley, it's junk.
^^ This.
It's not just the tensioner pulley, it's the rubber/spring insert thingy that the tensioner pivots on. A new tensioner assembly is in order. ;)
Re: Narrower belt?
Postby Diesel » Sun Aug 14, 2011 8:05 pm
So its not my compressor its the tensioner? Where can I get a good one?
Diesel
Re: Narrower belt?
Postby Hansen01 » Sun Aug 14, 2011 9:04 pm
i agree, dads jus went out on his 93, get it replaced asap affor it eats the belt, im sure napa or O rylies can get ya one
Hansen01
Re: Narrower belt?
Postby PToombs » Mon Aug 15, 2011 4:46 pm
Most auto parts, Cummins dealer, Dodge dealer, Case /IH dealer. If you go to the Case/IH dealer tell them you need it for a CX 240 excavator, it's the only one that's the correct one for our trucks. ;)
Re: Narrower belt?
Postby Diesel » Tue Aug 16, 2011 6:32 am
The issue is that I can see the AC pulley has a rib out of place. I'm almost positive it can't be the tensioner. The tensioner was so stiff when installing my new belt.
Diesel
Re: Narrower belt?
Postby Remps » Tue Aug 16, 2011 2:24 pm
Should be able to eyeball it from the passenger side, if it looks even slightly out of line with the other pulleys, replace the whole tensioner. I bought my tensioners from Napa, 60-70 bucks.
Re: Narrower belt?
Postby Luckydugan » Tue Aug 16, 2011 3:42 pm
Anybody make a better tensioner? Maybe one greaseable? :idea:
1993 Dodge W250 16cm Turbine Housing, Fuel pin, Spring, 60 HP Injectors, 3 1/2 " Exhaust, BD Performance Torque Convertor, ISSPRO Boost,Pyro,Tach,Tran Temp gauges. M/T Challenger Rims. 1993 Lance 900 ( 11'3').
Luckydugan
smoke screw?
Re: Narrower belt?
Postby Diesel » Tue Aug 16, 2011 7:49 pm
The tensioner is in line. The AC has a sharp rib that sits too far in and cuts a rib off. I'm just going to get a narrower belt in the same length.
Diesel
