Cooling 5x14 injectors
Postby Ram360man » Tue Oct 18, 2011 11:04 pm
Got my injectors in on Sunday along with some head studs. Trucks running at 50 pounds of boost and can hit 1600 degrees by the time it hits 90. I thought these would run around 1400-1500 at the max with my setup. Something messed up with my truck? Its always seemed to have ran rather hot.
1989 W250. Maxed fuel pump. 5x14. 63/68/14. PS Intercooler. 4200 gov spring. 188/220 cam. Built 727
1989 W250 60mm gds. 2.5 inch crossover. turned up pump. Stock 727.
Ram360man
Re: Cooling 5x14 injectors
Postby fatty » Tue Oct 18, 2011 11:06 pm
That sounds right to me for a small(ish) turbo, stock cam, stock head. Make sure your valves are adjusted right, air filter is clean, etc..
Postby Ram360man » Tue Oct 18, 2011 11:10 pm
Heads been rebuilt with new 3 angle valve job and some bowl blending. just set valves at .010 and .015. Air filter was recharged this morning.
Ram360man
Postby Ram360man » Tue Oct 18, 2011 11:16 pm
I'm at 1000 ft above sea level. Maybe that could be it. ;) Its not that high of an egt. Just was hoping for some cooler results. Needed an excuse for water/meth anyways.
Ram360man
Postby fatty » Wed Oct 19, 2011 7:00 am
Wow. I shouldnt post late at night. I thought I saw a 60mm GDS in your sig. :oops:
Postby Ram360man » Wed Oct 19, 2011 9:24 am
I was updating my sig when you posted. I could hit 1700 with the hybrid and stock injectors.
Ram360man
Postby Ram360man » Wed Oct 19, 2011 12:08 pm
Trucks been hazing when cold ever since the .020 head gasket went on. Head was shaved .010 so its only .010 higher. I'm using 9mm-7mm bushings though and they are really thick. just backed my timing down to stock and the truck wouldn't even start. I'll have to bump it a tooth when i get the chance.
Ram360man
Postby oldestof11 » Wed Oct 19, 2011 1:26 pm
More timing. Less timing you have, the more the exhaust burns in the manifold resulting in higher EGT's. Since you have a non-IC engine, advance that timing more. The bigger bowl of the pistons can take more timing than most 12v's. Adding more timing makes the fuel burn longer resulting in the heat staying in the cylinders longer.
Postby Hansen01 » Wed Oct 19, 2011 7:53 pm
Ram360man wrote:Heads been rebuilt with new 3 angle valve job and some bowl blending. just set valves at .010 and .015. Air filter was recharged this morning.
i thought that stock specs for valves were 8 and 10 or 10 and 12?
Under construction...
Hansen01
Postby collegekid » Wed Oct 19, 2011 9:07 pm
10 and 20
collegekid
Postby Ram360man » Wed Oct 19, 2011 11:20 pm
Timing was only 3/4 of the way to the head from stock. I put it all the way now with help from a ratchet strap and some sweet lovin with the 4 pound hammer. Still has some haze but lots better. Boost is now at 45 psi and 1475 egt. Much better but still needs more I think.
Ram360man
Postby Hansen01 » Thu Oct 20, 2011 8:18 pm
collegekid wrote:10 and 20
any advantage for setting them at 10 and 15 rather than 10 and 20?
sorry for thread derailment :roll:
Hansen01
Postby Ram360man » Thu Oct 20, 2011 10:39 pm
0.005 thousandths more valve lift on the exhaust side and slightly better spoolup. Some people say it helps. I honestly don't know. If it does help its probably marginal but every bit counts.
Ram360man
Postby Hansen01 » Fri Oct 21, 2011 5:39 am
hmm thanks, il have to try 10 and 15 :D
Hansen01
Postby ahale2772 » Fri Oct 21, 2011 6:19 am
I dont think 5 thousands of lift is enought to warrent the risk of ruining a valve seat.... IMO
