fuel shutoff solenoid
Postby danc » Tue Oct 18, 2011 8:51 pm
I joined the pull cable club 6 months ago but I am worried that the solenoid may be restricting fuel into the IP. Do I need to pull the pump head to get the solenoid out or can I squeeze it by with out pulling the head ,or is it ok as is. I was going to pull the it and remove the tip and the spring and put it back without the wire. If anyone has any tips or trick to making this any easier would be great. THANKS
1993 club cab 2wd, auto,s300,5x14s,BHAF,powertrax,denny t, Carter 100gph,specrite tc, built 518,tampered pump,and a new headliner.
danc
Re: fuel shutoff solenoid
Postby ellis93 » Wed Oct 19, 2011 4:06 am
There is a pump support bracket that will interfere with getting a wrench on the solinoid. I had to pull the bracket off and it came right out.
Postby CumminsPower59 » Wed Oct 19, 2011 4:34 am
Mine came out with the bracket stil in place, took a little bit of patientce, but it comes right out ;)
Postby ellis93 » Wed Oct 19, 2011 5:50 am
CumminsPower59 wrote:Mine came out with the bracket stil in place, took a little bit of patientce, but it comes right out ;)
:D I don't have that much patients :lol:
Postby Tsbourne09 » Wed Oct 19, 2011 12:04 pm
mine has went out and i have had a pull cable for some time now (just recently made a nice pull cable setup). sould i pull mine out and strip it?
Not On Yet: 60#VS
Tsbourne09
Postby PToombs » Fri Oct 21, 2011 5:20 pm
For you guys that fight around the bracket, just cut it off where the holes are in it. There are several approved methods, bend it back and forth with a crescent wrench until it pops off, cut it off, or a combination of both. I cut mine part way with a cut off wheel on the 4" grinder, then bent it about 3-4 times and it was outta the way.
Postby Tsbourne09 » Fri Oct 21, 2011 7:08 pm
I cut mine off. Sould i pull mu fss out and strip it?
Not On Yet: 60#VS
Tsbourne09
Postby cougar » Sun Oct 23, 2011 8:15 am
I modified a deep offset wrench to fit in there.
01 2500 "the work truck".
cougar
Postby oldestof11 » Sun Oct 23, 2011 12:51 pm
Just did mine with a sharp chisel. Took 30 mins max. I removed the up-pipe and took off the throttle bracket. Also, get that little nut off and the tabs. A good 1/3 of my sealing surface was chiseled away...
Postby Tsbourne09 » Wed Oct 26, 2011 8:31 pm
I cut my braket off a while back. but today after i finished the install of my denny t afc delete pump top i removed my bad fss and took the chipped rubber stopper comletele off! Look at my photo bucket and u will see my pics. Had large amounts of chewed rubber in a screened banjo. I just wonder whts in my delivery valves...
Not On Yet: 60#VS
Tsbourne09
Postby Tsbourne09 » Wed Oct 26, 2011 8:32 pm
And i can remove my fss in less than a minute with the right wrench. Not hard if u kbow wht u r doing and have the right tool. I recomend cutting the braket.
Not On Yet: 60#VS
Tsbourne09
