Leaking IP AGAIN!!!
Leaking IP AGAIN!!!
Postby collegekid » Thu Oct 20, 2011 6:53 am
So I ground down my fuel pin last night and finally put the 366 spring in and took it for a drive. I looked this morning and I'm leaking fuel out the back of the pump (between head and IP). I just had this pump rebuilt by a cummins pump guy 3,000 miles ago, is this normal for these pumps to blow every time you add power to them, or is mine just being difficult.
collegekid
Re: Leaking IP AGAIN!!!
Postby Hansen01 » Thu Oct 20, 2011 8:26 pm
how much fuel pressure are you running? i mess with mine all the time and dont have but a little overflow spitting out once in a while
Under construction...
Hansen01
Postby KTA » Fri Oct 21, 2011 6:00 am
If you get on it with the ksb engaged you can often times blow out the timing piston o rings.
Postby collegekid » Fri Oct 21, 2011 5:53 pm
Im running 15, my ksb isnt hotwired, and I always let it warm up before ever getting on it, ksb just advances the timing when you first start it up and when its cold true?
collegekid
Postby dazedandconfused » Fri Oct 21, 2011 6:18 pm
From my limited knowledge if it's always got 12V hot going to it you always have it energized. It only comes on for a certain point and kicks itself off if it's wired from factory.
Postby Hansen01 » Fri Oct 21, 2011 7:13 pm
dad runs his at 10 and hasnt had any trouble, id try backing the pressure down just a little bit
Hansen01
Postby collegekid » Fri Oct 21, 2011 9:45 pm
pulled the pump top, the gasket that goes around the pump top slipped out of the track, problem solved, hansen, i had my pump loctited together, so it should "theoretically" hold up to 20psi....can someone explain the ksb in greater detail, bypassing it, making it "better" or less of a problem
collegekid
Postby Hansen01 » Fri Oct 21, 2011 10:37 pm
hmm locktite, good stuff lol nvm me then :D
Hansen01
Postby collegekid » Sun Oct 30, 2011 4:45 pm
Can you loctite your pump head so that it doesn't blow out, I keep blowing the gasket around the pump head, also, is there anything else that I should do to the pump as far as tuning or afc stuff while I'm in there
collegekid
Postby oldestof11 » Sun Oct 30, 2011 5:20 pm
If you are blowing that seal, I would think something, somewhere is warped. I would see if new bolts fix it. Maybe 1 stretched???
Postby collegekid » Sun Oct 30, 2011 5:38 pm
I guess I didn't think about that, whats the torq supposed to be on those bolts?
collegekid
Postby Tsbourne09 » Sun Oct 30, 2011 7:19 pm
I would like to know more about ksb aswell
Not On Yet: 60#VS
Tsbourne09
