Turbo off 97 2500. Hx35
Postby Tsbourne09 » Wed Nov 02, 2011 1:51 pm
Guy is offering me a turbo Off a 97 2500 cummins with 180k miles for $100... Should i get it? Is that a good turbo? What are the specs on it? What are the specs on my 93 h1c?
Not On Yet: 60#VS
Tsbourne09
Re: Turbo off 97 2500. Hx35
Postby collegekid » Wed Nov 02, 2011 4:47 pm
Itll help out, thats a lot of miles though....shaft play would be my main concern with it, followed by chipped blades, idk how much a rebuild kit is, but it may be worth it, others will know more
collegekid
Postby oldestof11 » Wed Nov 02, 2011 5:32 pm
Mainly good for the exhaust housing.
The compressor is just a tad bigger and flows somewhere around 4-5lbs/min more than the H1C.
The thing I would be slightly concerned is shaft play and your auto. 12cm is going to be tight on the upper RPM range.
Postby Tsbourne09 » Wed Nov 02, 2011 6:53 pm
Shaft play was very little! He let me have it for $50 and i took it to a custom/performance shop and they said it was perfect and worth every bit of $300!!!!! They are powdwe coating it black and the same color blue of my valve covers! Awsome! What arethe apecs on it like size wise
Not On Yet: 60#VS
Tsbourne09
Postby oldestof11 » Wed Nov 02, 2011 7:49 pm
57/57/.63ish...
Postby elm302 » Wed Nov 02, 2011 7:49 pm
You stole that thing I just paid 250 for one.
93 W250 Getrag Valair clutch HIDS 3200 spring Denny 2 pin M&H spacer Airdog 150 5x16s 63/68/.91 4" duals Isspro gauges BHAF 2nd gen intake water meth 60# springs 3 piece manifold. Next up PS intercooler
elm302
Postby collegekid » Wed Nov 02, 2011 7:55 pm
with how many miles tho?
collegekid
Postby elm302 » Wed Nov 02, 2011 7:58 pm
Around a 100 k I believe
elm302
Postby Tsbourne09 » Wed Nov 02, 2011 8:11 pm
Mine had 180k on it.. So said but the turbO was near perfect! Imma say it has been replaced in the past
Not On Yet: 60#VS
Tsbourne09
Postby collegekid » Wed Nov 02, 2011 8:35 pm
then thats a really good find, post up some pics
collegekid
Postby Tsbourne09 » Thu Nov 03, 2011 6:46 am
I will. Its at exotics getting powdercoated. I pick it up next week!
Not On Yet: 60#VS
Tsbourne09
Postby Tsbourne09 » Thu Jan 05, 2012 11:26 pm
Update... Got hx35 housings through 1st stage of coating. Waiting on special clear with metalic in it. Will repost pics when they are finished. Wait untill you see what the valve cover-cover is gunna look like..
Okk diddnt want to start a new thread but has anyone ever done a h1c over hx35? I know it sounds useless but it would look cool. Anyone have opinions or experiance in this? Thanks. Please dont call me dumb lol.
Not On Yet: 60#VS
Tsbourne09
Postby delinquent » Thu Jan 05, 2012 11:46 pm
won't work. effect is minimal at best. look for ht3b's or s400's. Used prices range in the 300-500 range with new being 650-750.
delinquent
Postby Tacoclaw » Fri Jan 06, 2012 7:01 am
Yeah, it'll be pretty pointless. You do twins when you're running your current turbo off it's map due to it not getting enough air in its inlet. An HX has almost the same wheel inlet diameter as a H1C, so your system will still be pulling through the same hole.
If you think it looks cool, and are able to pull it off for relatively cheap, then go for it. Don't expect huge power gains, and expect some hate from people who don't get why you'd bother.
Postby oldestof11 » Fri Jan 06, 2012 8:08 am
Tsbourne09 wrote:Update... Got hx35 housings through 1st stage of coating. Waiting on special clear with metalic in it. Will repost pics when they are finished. Wait untill you see what the valve cover-cover is gunna look like..
The idea of compound turbos is to ramp up the pressure on a low pressure high flow turbo. A small turbo fedding a slightly smaller one is moot. That is like taking a 1/2" water line and hoping to get more when you connect it to a 3/8" water line. What the true idea is taking a 3/4" line and knowing its too bigg for the fitting at the end and it needs slightly more pressure to make it right so you downsize it to 1/2".
