Install issues with Raptor 150 fuel pump
Postby 93DodgeCummins » Fri Dec 09, 2011 10:25 pm
I started installing my raptor fuel pump and was installing my male fuel fitting that screws into the inlet side of the stock fuel filter on the intake manifold. I found out that my throttle and cruise control bracket on the engine is in the way. Can anyone help me?
93DodgeCummins
Re: Install issues with Raptor 150 fuel pump
Postby 93DodgeCummins » Sat Dec 10, 2011 9:28 pm
Here is another picture with the fuel elbow snapped on. The throttle bracket is barely hanging on because it binds up with the new fuel fitting and elbow
93DodgeCummins
Postby Hansen01 » Sat Dec 10, 2011 11:03 pm
can you bend anything down, or sideways or anything?
Under construction...
Hansen01
Postby 93DodgeCummins » Sun Dec 11, 2011 8:24 am
maybe but i dont wanna mess up my cruise control. has anyone else installed a raptor pump and ran into this problem?
93DodgeCummins
Postby oldestof11 » Sun Dec 11, 2011 11:45 am
I think most, if they go this far, remove the restrictions of the stock fuel filter and go remote mount.
Postby 93DodgeCummins » Sun Dec 11, 2011 4:36 pm
well my plan was to stay with the stock filter for now.
93DodgeCummins
Postby Tsbourne09 » Wed Dec 14, 2011 10:51 pm
hey! had the same problem. FLIP IT UPSIDE DOWN AND MOUNT FROM THE BOTTOM. its hard to snap in but it will work! be sure you turn your pressure all the way down before you turn it over or you will risk blowing the ip seals. happend to me. came preset at over 30psi. the lowest it goes is like 8psi so you can turn it all the way down, start it, then go up from there. flip that bracket and a few wire ties to keep my fuel line off my manual shut off cable is the only alterations i made. may have pics in my photobucket and if not i will snap a few in the morning for you.
Not On Yet: 60#VS
Tsbourne09
Postby Tsbourne09 » Wed Dec 14, 2011 10:52 pm
you need a fuel pressure gauge to be safe.
Not On Yet: 60#VS
Tsbourne09
Postby Tsbourne09 » Wed Dec 14, 2011 10:56 pm
i will take pics of the hook ups and how i flipped the cable/bracket 2mar. simple.
Not On Yet: 60#VS
Tsbourne09
Postby 93DodgeCummins » Thu Dec 15, 2011 5:18 pm
did your pump have a screen in the inlet? Please get some pics soon. I really want to get it finished this weekend
93DodgeCummins
Postby 93DodgeCummins » Mon Dec 19, 2011 10:12 pm
I got it figured out. I set up a relay for the pump and flipped the cruise control cable upside down on the bracket. Pump sounds really healthy. I will make a video and post it when i get time
93DodgeCummins
Postby Tsbourne09 » Tue Dec 20, 2011 2:39 pm
Lol n now i got u pics...
Wired it to ignition
Not On Yet: 60#VS
Tsbourne09
Postby 93DodgeCummins » Tue Dec 20, 2011 4:52 pm
Wow you have a clean engine. Mine is kind of a mess..
93DodgeCummins
Postby Tsbourne09 » Tue Dec 20, 2011 5:21 pm
thanks. lots of work. good luck hope i helped
Not On Yet: 60#VS
Tsbourne09
Postby 93DodgeCummins » Tue Dec 20, 2011 9:40 pm
You definitely helped! I love the sound of my pump sounds really cool. Did u pull the motor and clean it up? It really makes me jealous to see how clean yours is.
93DodgeCummins
