second gen seats?
second gen seats?
Postby jacobwebb57 » Tue Jan 03, 2012 7:30 pm
has anyone put second gen seats in our trucks? my buddy wrecked his 99 had i was gonna buy teh seats off him.. they are the ones with the seat belts inside the seat will these still work?
91.5 4x4 5 speed, dennyt stage 2. ddp 50 horse injectors. glow shift boost, fuel pressure, egt, autometer tach, 60lb vavle spring, 3800 gov springs, 1 ton axles, custom intake, 4'' exaust, hx35w pump turned up 3 turns raptor pump, and 1/8 timing.. new injectors sooner or later
jacobwebb57
Re: second gen seats?
Postby Hansen01 » Wed Jan 04, 2012 12:06 am
i jus bought a set also, they will fit, jus gotta figure out how you wanna do it lol
its not a direct bolt in :)
Under construction...
Hansen01
Postby jacobwebb57 » Wed Jan 04, 2012 6:21 pm
i knew they wouldnt bolt up. i work at a welding shop so it wont be hard to make a bracket up to muont them. i was more concerned if they will fit width and the length. but you say they will so thank you
jacobwebb57
Postby Hansen01 » Wed Jan 04, 2012 7:10 pm
lenth and width is good, i jus got mine in today, you jus gotta have spacers for the back. and you gotta drill new holes, in my case it wouldnt hurt to cut the front mount down about an inch
Hansen01
Postby bmoeller » Wed Jan 04, 2012 9:35 pm
I have a '99. The seats flat SUCK!!!!!!! The ones I had in the '97 were great. These others kill my back side. :( Feel like sitting on nails, if in them long enough. Going to NY and CO was pure pure hell!
SOLD- '99 3500, SO CTD, 5spd
bmoeller
Postby Hansen01 » Wed Jan 04, 2012 9:43 pm
i jus like haveing a center console, :D
mine were from a 99 to, they may still not be super cumfy but i like them alllooot better than the bench lol
Hansen01
Postby jacobwebb57 » Thu Jan 05, 2012 7:31 pm
thanks for the input guys
jacobwebb57
Postby Hansen01 » Thu Jan 05, 2012 8:32 pm
:thumleft:
Hansen01
Postby PToombs » Sun Jan 08, 2012 8:46 am
Bryan, are the RC seats as good as you thought at 1st?
My '97 seats aren't bad, and I have the cheap, flatish non power '96 seats in my '92. I cut the fronts down to keep it just above the stock bench height. Biggest problem is they are just too damn close to the steering wheel in a regular cab truck. :(
Postby jacobwebb57 » Mon Jan 09, 2012 6:47 pm
well to close is ok with me bc im short lol
jacobwebb57
