Tacoclaw wrote:I'm running out of excuses to ignore this thing...![]()
For anyone still wondering why you need to bottom tap the headbolt holes with A1 studs:
That's with 1 thread above the nut and the bottom of the washers even with the flange on the factory bolts. That's a lot of tapping.
Tacoclaw wrote:How's those 5X18s treating you?
I'd skip the full cuts if I was you, you're truck is going to be a smoky pig and no turbo will stop that.
Tacoclaw wrote:I chuckled in anticipation of hearing about all the cracks my head had in it. The machine shop guy at Carquest always seemed paranoid about the smallest cracks a head had. I'd never sent one in that he "approved" of.
This time however, there's a crack from the injector hole, behind the seat, and all the way up into the intake port. Not even I am ok with that, as a dropped seat is bad news.
I knew I should have just bought a Hamilton head to begin with, now I'm looking for a reman/use stocker to hold me for a whole.
