bullydog fuel pin
bullydog fuel pin
Postby cummins king » Fri Oct 26, 2007 8:56 pm
a few mouths ago i bought a bullydog fuel pin. just the other day i pulled it out to find a deep gash in it 1/16 th of an inch, call bullydog up told them whats up and they said that im there first case, i know the pin wasnt hardend enough thats why it happened, any body else have that problem?, they said send it back and i will get a refund, perfect 200 bucks back and now i will remove the acv or what ever its called leaver in the pump
if you got a bullydog fuel pin probly be a good idea to check it :!:
93 4X4 auto
cummins king
Postby Begle1 » Fri Oct 26, 2007 9:10 pm
I've heard of the BullyDog pins being insufficiently hardened. Other people have had that option.
No Problem Here
Postby Ace » Sat Oct 27, 2007 6:39 am
I looked at mine a coulpe days ago after seeing Wanna's report about Ruquick's BD pin. Looks fine. Been in there since July or thereabouts, as I recall.
Re: No Problem Here
Postby JD730 » Mon Oct 29, 2007 5:23 am
Ace wrote:I looked at mine a coulpe days ago after seeing Wanna's report about Ruquick's BD pin. Looks fine. Been in there since July or thereabouts, as I recall.
I would keep an eye on it.
I was in the shop when they pulled it out of the pump and showed it to me to see what I thought of it. Not very hard, hardness needs to be at least 42Rc (Rockwell C scale for those of you that don't know).
Wanna is running a pin I made, I didn't get a chance to see it, but the only mark on it is a witness mark from the other pin.
Mike
The "Rattle Box"
JD730
I wonder...
Postby Ace » Wed Oct 31, 2007 7:53 am
Maybe they had bad run of pins from a supplier somewhere? I could see wear scars (witness marks, as you called them) but that was it. I also lubed the face of the pin where the action is, so I'm sure that helps. We'll see...
Postby BobS » Wed Oct 31, 2007 11:31 am
Are they made in China?
BobS
91.5 W250 NV4500 Conversion
89 D350 Stock
BobS
bd pin
Postby cummins king » Wed Oct 31, 2007 6:22 pm
lol, china, im sending mine back guys going to give my money back, and he says that hes not going to sell them anymore, untill he resives a hardnes report
93 4X4 auto
cummins king
Postby Makaio » Wed Oct 31, 2007 9:45 pm
Cummins King,
Well, just checked mine today after reading your post and it DOES have a slight groove. :x I installed it about a year and a half ago. I need to dig through my receipts as I can't remember where I bought it from. Bully Dog was out at the time and I found it on another website. I'll be contacting them in the morning about this. Glad you posted this. I probably would have never checked it.
Aloha,
Matt
Matt
1992 W250 auto, ASA/AFE intake, H1C hybrid 60-16, Bosch 190's, Bully Dog fuel pin, 366 spring, modified pump and a 4" turbo back exhaust. Suncoast valve body plumbing 3.54's w/LSD. Autometer gauges.
Makaio
