Turbo off 97 2500. Hx35
Re: Turbo off 97 2500. Hx35
Postby cmann250 » Fri Jan 06, 2012 10:28 am
If you wanted to be unique, you could run "twin" turbos. For example, the H1C feeding cylinders 1-3 and the HX35 feeding 4-6. It would be a nightmare to plumb, exhaust and air-wise, especially with an intercooler. But i'd wager you'd be the only one in your area to do such a thing :lol:
Postby Tacoclaw » Fri Jan 06, 2012 11:08 am
He said cool, not unique.
Compounds definitely look cool, so you can't fault him for wanting them. I just don't see twins looking all that cool compared to compounds. The only good thing about them would be having true dual exhausts, and all the cool kids are doing triples for that anyways. :grin:
Postby cmann250 » Fri Jan 06, 2012 3:55 pm
2>1, especially in turbos :lol:
It'd be interesting to see twin HX35s, a manifold that you can mount 2 turbos on, twin cross over pipes, 2 down pipes combining into one exhaust. I'd bet it would be pretty efficient and run cool.
But not interesting enough for me to try it, see my sig ;)
Postby Tsbourne09 » Sat Jan 07, 2012 2:03 am
Would it be better than a single h1c or hx35? I could run all my own piping so i could keep the costs down... I know it sounds useless but i think it would be neat and benifit slightly from it... Compounds are cool in general. Haha
Not On Yet: 60#VS
Tsbourne09
Postby cmann250 » Sat Jan 07, 2012 5:53 am
Here is where terminology gets confusing. To me, compounds indicates one turbo feeding another. Twins technically means two of the same sharing the load, in my mind. I offend as bad as any in this area.
True twin turbos would split the work. They wouldn't spool faster and I don't think you could get any more boost, but it would for sure look and sound cool. I just can't see where one turbo feeding another of roughly the same size does much good
Tsbourne- you have a PM
Postby oldestof11 » Mon Jan 09, 2012 4:30 pm
I was told 24v guys tried this once. Twin HX35s with a split exhaust manifold. It would constantly surged and never really spooled.
Now twin HE351 VGTs and you are golden.
Postby Tsbourne09 » Tue Jan 24, 2012 6:00 pm
got the bad ass hx35 on and all i can say is holy crap. it lights up super fast and truck now pushes 50ps. it was def worth the 50 plus powder coating i put in it. i love it!!! also it sounds amazing!
also i left w/g unplugged for now. hit 52 at wot for a few secs. love it!!!
Not On Yet: 60#VS
Tsbourne09
Postby Tacoclaw » Tue Jan 24, 2012 6:05 pm
52psi will probably make for a pretty short lifespan for that HX FWIW.
Might wanna throw the 'gate back on and drill it out if need be to keep it down. Those things are spinning hella fast to get that much PSI built up.
Postby peobryant » Tue Jan 24, 2012 7:44 pm
Tacoclaw wrote:52psi will probably make for a pretty short lifespan for that HX FWIW.
I'll agree with him. Although I'm not quite sure what "hella" means I do know that an HX35 is living on borrowed time if you keep it pushing 50psi. You're way out of it's map range and it's jus blowing hot air after about 30-35psi. Sounds like you need a bigger turbo. :)
Postby AHineman » Tue Jan 24, 2012 7:46 pm
peobryant wrote:Although I'm not quite sure what "hella" means
Levi's been watching too much southpark. :lol:
Postby Tacoclaw » Tue Jan 24, 2012 8:53 pm
Sorry, Grandpa, I'll turn my music down. :P
That is a nice looking coating by the way. 8)
Postby oldestof11 » Wed Jan 25, 2012 5:11 am
I was told that at 32psi on the HX35 is around 130k shaft rpms. I can only imagine how fast it is spinning at 50psi. :shock:
