recommended injector FOR towing
Re: recommended injector FOR towing
Postby ellis93 » Mon Feb 20, 2012 8:33 pm
I'll let ya'll know for sure. I thing about it it'll be worked with them. If they make it run to hot then they'll be for sale :lol:
Postby Tacoclaw » Mon Feb 20, 2012 9:31 pm
If they make it run too hot you'll finally have a reason for twins, not just a curiosity. :mrgreen:
Postby tampabayBill » Tue Feb 21, 2012 9:42 am
Ellis, I ran 7x10s with a HTT stage 4, which is about the same as your turbo, and the other mods in my sig. I tow a 35 ft fifth wheel that weighs 12600 lbs empty with no problem. I never saw egt's above 1100 but its been pretty much flat towing ie no mountain travels. My 7x10's were from New Era............Bill
Twins coming soon!
tampabayBill
Postby Black93 » Tue Feb 21, 2012 1:12 pm
tampabayBill wrote:Ellis, I ran 7x10s with a HTT stage 4, which is about the same as your turbo, and the other mods in my sig. I tow a 35 ft fifth wheel that weighs 12600 lbs empty with no problem. I never saw egt's above 1100 but its been pretty much flat towing ie no mountain travels. My 7x10's were from New Era............Bill
How were they power wise?
Black93
Postby tampabayBill » Tue Feb 21, 2012 3:19 pm
Less than the BD 40 hp ( POD"S ) I was running. The 7x10's run alot cleaner, I think the difference in fuel pins, bully dog to an M3 also made a diff. - the M3 is must less agressive. Still I like the 7x10's a good towing setup very close to 5x12's and gave good responce and milage and they weren't hot. My normal cruising egt's were 500/600 degrees.............Bill
Twins coming soon!
tampabayBill
Postby PToombs » Tue Feb 21, 2012 6:34 pm
5 X .012 are damn hot for towing unless you have a real good turbo. BTDT. An aftermarket cam may help quite a bit, from what Alex has experienced lately.
Postby ellis93 » Tue Feb 21, 2012 7:07 pm
PToombs wrote:. An aftermarket cam may help quite a bit, from what Alex has experienced lately.
I thought of the same today and I've noticed tampa has one in his truck.
Here's the other thing with mine thou, I've never fooled with the fuel screw on mine either. Mostly because if I mashed on it hard with a load the needle on the pyro looked like it belonged on a pro-street cars speedometer. I've had my suspicions my stock injectors have been bad for awhile,under load and pushing it I can bust 1200 quick.
Postby tampabayBill » Wed Feb 22, 2012 8:07 am
I did everything I could think of to get MORE air before I started to add fuel. Cam, ported head, turbo, 4 in exht, 3 piece exhaust, Cooler Tubz and upgraded intercooler. 47RH comes next along with some work on cooling system and maybe down the line twins ( have the S471 just waiting )). So my truck, like most of yours is a work in progress. My goal has been a powerful daily driver that can latch onto my 5th wheel and tour the U.S. and Canada with no problem. Its getting there slow but sure, its been alot of fun and I've learned alot on this site so I'll say thanks for all the info guys- hope I can help someone down the line..............Bill
Twins coming soon!
tampabayBill
Postby Diesel Dawg » Thu Feb 23, 2012 1:59 am
subscribed! Would like to hear how the 7x10s work aswell.
Diesel Dawg
Postby Greenleaf » Thu Feb 23, 2012 4:57 am
I like the BOSCH 180's They provide plenty of power, but they won't get too awful hot with a modified injection pump.
I have tried these in a school bus too, loaded with kids on a very long hill climb and they perform wonderfully. They will show some smoke, but nothing like 370's or POD's
I have the part number if anyone is interested.
Greenleaf
tech specialist/mod
