roosamaster?????
roosamaster?????
Postby ford69557ci » Tue Nov 06, 2007 8:02 pm
What is this roosamaster pump i keep hearing about? i guess it is a rotory pump, but can it move alot of fuel seems like i hear about it on the lower class pull tractors?
ford69557ci
Postby JD730 » Wed Nov 07, 2007 5:41 am
Its a distributor style pump, but instead of having a rotating axial piston, its simplest form has 2 opposed radial pistons that are forced towards each other by a cam ring. The cam ring's timing is variable similar to the VE's.
From what I hear they can be modified to push something like 450cc of fuel.
Mike
The "Rattle Box"
JD730
Postby DTanklage » Wed Nov 07, 2007 9:56 am
if i were you i would stick to your original idea and p-pump it
DTanklage
Postby ford69557ci » Wed Nov 07, 2007 11:28 am
nah first i am goin to beat the ve record on #2 the i am goin to set the power adder record
ford69557ci
Postby DTanklage » Wed Nov 07, 2007 1:11 pm
josh went 600/1300 with one solenoid
DTanklage
Postby cummins king » Wed Nov 07, 2007 7:48 pm
not if i can beat you first Mr.ford :evil:
93 4X4 auto
cummins king
Postby ford69557ci » Wed Nov 07, 2007 8:00 pm
well im up for the challenge i have almost everything i need to put it together besides the turbos and that will be in a few weeks hopefully
ford69557ci
Postby GPSMatt » Wed Nov 07, 2007 10:49 pm
isnt that the pump that they have in the IDI's i ordered a rebuild kit for one of mine nad it said it was for standyne/roosamaster
86 F350 idi
85 F350 crew cab 4x 5.9
95 Lightning
85 GT
GPSMatt
Postby ford69557ci » Wed Nov 07, 2007 11:24 pm
it very well could be but it also popular in the tractor pullin circuit
ford69557ci
Postby GPSMatt » Wed Nov 07, 2007 11:30 pm
Yeah they are the pumps that come in the 6.9/7.3 and hte 6.2/6.5 Do they have a lot of potential? I have heard of some IDI guys pullin big power with them.
86 F350 idi
95 Lightning
85 GT
GPSMatt
Postby KTA » Thu Nov 08, 2007 7:32 am
The only Roosamaster DB or JDB pumps I know of making over 500hp are the tractor pulling ones, and they can only last about 40 times going 300ft. The custom part big headed DB4's beat themselves apart and usually seize the head and rotor.
Postby dpuckett » Thu Nov 08, 2007 7:32 pm
I had never heard of any high HP longevity with the Stanadyne/ Roosamaster (precursor) pumps. Longevity is troublesome with stock 50-60cc.
The VE is much bigger and heftier.
DP
Postby Greenleaf » Fri Nov 23, 2007 7:11 am
Th old Roosa pump (now a Stanadyne Co.) was intened for small John Deere engines. When Deere became serious about big engines and big HP, they began to use the Nippo pump, which looks like a P-series.
One will not find an old Roosamaster in a John Deere 4320 on the pulling
track.
Greenleaf
tech specialist/mod
Postby fasttalker83 » Sun Jan 27, 2008 10:27 pm
Im going to college right now for diesel pumps and actually the nippo pump and system had less power than a roosa system on combines on a JD 9600 when they first come out was to have a high hp engine and a low hp engine what happend is the first ones had nippo injection systems which won the contract first and a roosa system came out later the same year and beat them by 75hp but the first motors couldnt take the extra 75hp due to heat and not built for it heres my 2cents
fasttalker83
Postby GPSMatt » Fri Feb 01, 2008 3:48 am
Kind of off topic but i am building a pumped idi for one of my trucks what other good 8 cylinder pumps are out there
86 F350 idi
95 Lightning
85 GT
GPSMatt
