by THE TANK1 » Thu Nov 15, 2007 7:28 pm
[quote="DTanklage"]i dont have any experience with pulling trucks but for drag racing motorcycles the guys that are running stock heads they stick with '84 gpz cams (256° @ .050" - .385" lift). those were the biggest stock cams that kawi made. by stock head i mean a head that came on a bike stock. obviously they all port them and put larger valves in.
the guys using after market heads use more cam than the stockers, but the turbo bikes dont want a bunch of camshaft.
the gpz cams are good for low 7's
to go high to mid 6's you need aftermarket head and cams
So you are saying I can run low 7's with that cam
1990 dodge 550 monkey pump, stacks, southbend DD,
