Pro 52?
Pro 52?
Postby THE TANK1 » Mon Nov 12, 2007 5:38 pm
Can a 1st gen spool this with 6x18's, 14mm head.
1990 dodge 550 monkey pump, stacks, southbend DD,
THE TANK1
Postby DTanklage » Mon Nov 12, 2007 5:42 pm
it would spool just about any turbo with an injector that big
question is - at what rpm will it spool it...
DTanklage
Postby THE TANK1 » Mon Nov 12, 2007 7:15 pm
all it is used for is pulling, I thought there was someone on here that was runnig one?
THE TANK1
Postby KTA » Mon Nov 12, 2007 7:33 pm
Bill Gilbert on here runs that setup about 450rwhp on an all stock motor.
Postby cummins king » Mon Nov 12, 2007 7:35 pm
u would have to run a serious set of turbos to get any really usfull power out of it
93 4X4 auto
cummins king
Postby THE TANK1 » Mon Nov 12, 2007 7:57 pm
What does Bill use the truck for? you dont think you can use that big of a turbo. I am tearing the motor down this winter, I would like to stay with the VE pump. I need input on low comp pistons, cam and so on. Just pulling with the truck thanks
THE TANK1
Postby DTanklage » Mon Nov 12, 2007 10:44 pm
i wonder how the map for a pro 52 compares to one for a 66/71 or 66/75?
that is one big turbo - i think he just uses the truck for playing
you know what i mean?
he likes to beat up on high school kids like josh ayers...
lol
jk bill
DTanklage
Postby GPSMatt » Tue Nov 13, 2007 3:06 am
http://1stgen.org/viewtopic.php?t=1401
Low comp pistons were talked about here.
86 F350 idi
85 F350 crew cab 4x 5.9
95 Lightning
85 GT
GPSMatt
Postby THE TANK1 » Tue Nov 13, 2007 6:55 pm
what about a cam for this truck, hasiley has one for 700ish that requires fly cuts any input?
THE TANK1
Postby DTanklage » Tue Nov 13, 2007 7:42 pm
i dont have any experience with pulling trucks but for drag racing motorcycles the guys that are running stock heads they stick with '84 gpz cams (256° @ .050" - .385" lift). those were the biggest stock cams that kawi made. by stock head i mean a head that came on a bike stock. obviously they all port them and put larger valves in.
the guys using after market heads use more cam than the stockers, but the turbo bikes dont want a bunch of camshaft.
the gpz cams are good for low 7's
to go high to mid 6's you need aftermarket head and cams
i know that a turbo gas motor is way different than a diesel, but i think the princible may be the same when it comes to cams (turbo motors dont need a bunch cuz they dont rev very high)
DTanklage
Postby ford69557ci » Tue Nov 13, 2007 9:34 pm
way different concept between gas and deisel. i run a 670-755 lift 328 346 duration 115 lsa in my turbo small block s 10. i dont think a cummins would like anything near that. and i steped up from last years cam and gain aound 20whp so sometimes bigger is better now if i could just get a lasting turbo
ford69557ci
Postby DTanklage » Tue Nov 13, 2007 10:54 pm
775 lift on the ex lobe???
what is the duration at 050 on the ex?
don
ps - that is crazy huge lift for a small block
DTanklage
Postby ford69557ci » Wed Nov 14, 2007 5:31 pm
i dont remember i would have to call howards and find out but with the hendricks ported sb2.2 heads and the very large turbo its isnt to big of a cam and i drive this thing on the street 2 or 3 times a week with a 5800 converter with a braked glide sound like fun hahaha
ford69557ci
Postby THE TANK1 » Thu Nov 15, 2007 7:28 pm
[quote="DTanklage"]i dont have any experience with pulling trucks but for drag racing motorcycles the guys that are running stock heads they stick with '84 gpz cams (256° @ .050" - .385" lift). those were the biggest stock cams that kawi made. by stock head i mean a head that came on a bike stock. obviously they all port them and put larger valves in.
So you are saying I can run low 7's with that cam :P
THE TANK1
Postby DTanklage » Thu Nov 15, 2007 8:39 pm
no, i am saying that i dont know if you are going to see very much additional hp for the $700 you are gonna be dishin out
not to mention what a pain in the ass it is to swap the cam in this thing
DTanklage
