blown headgasket
blown headgasket
Postby odee » Wed Nov 28, 2012 7:42 pm
Guys, running a 5.9 in my chevy dually. The engine is a 89 model. I have to replace the headgasket pushing coolant to the puke tank. What is the best gasket to go back with? Replace the bolts or go with the studs? Best place or vendor here to pick up the parts.
odee
Re: blown headgasket
Postby dazedandconfused » Wed Nov 28, 2012 7:51 pm
Use a stock Cummins gasket. What are the mods and goals with the truck?
Postby odee » Wed Nov 28, 2012 7:58 pm
no real mods planned, I've got a different turbo from a 98 up with the exhaust brake, planning on doing the valve springs while head is off. I have the 94 and up ic on the truck also. I like the power the truck has right now. Truck is used as a tow rig for the drag car and jeep, some dd and road trips with the wife.
odee
Postby dazedandconfused » Wed Nov 28, 2012 8:03 pm
I would have head checked for cracks and flatness then just rum a tap down the holes to clean the threads and use stock bolts. There is a gauge that tells how much stretch is allowed in the stock studs.
Postby bmoeller » Wed Nov 28, 2012 8:10 pm
Gauge, or not, I won't re-use them.
Stock gasket would be the best. Don't cheap out on it, or you'll get to go it again. Make sure to lube the threads and under the head of the bolts.
And, a BOTTOM tap would be best to use. Can clean out more of the hole. Not tapered at the bottom.
SOLD- '99 3500, SO CTD, 5spd
bmoeller
Postby odee » Thu Nov 29, 2012 3:53 pm
so,I can pick up a stock felpro at my work or should I check at the dodge dealer or cummins dealer for their brand gasket? Bolts come from dealer also? thanks guys just want to do this one time.
odee
Postby dazedandconfused » Thu Nov 29, 2012 4:00 pm
For the headgasket I will only use genuine Cummins. Ive heard mixed reviews on Victor Reinz.
Postby revemup15 » Thu Nov 29, 2012 6:30 pm
Get the redsigned felpro.... just recently i bought one... sat it next to my cummins one and looks IDENTICAL! .... remember get there new stock felpro gasket... the old design was garbage... 9313pt is the part number for the new designed hg.. good luck
94 p-pump
revemup15
Banned
Postby RCCUMMINS89 » Thu Nov 29, 2012 7:47 pm
Would be a good idea to take your old one in, if you go with a newer felpro. I personally have not seen the new ones, but the old ones, I wouldn't put on a lawnmower. Side by side, you'll know if they are giving you the new one or not.
The Victor Reinz, looks very similiar. But, it is not as good of quality.
