Fuel pressure question
Postby cummins12club » Mon Dec 31, 2012 12:07 am
What is the highest psi I can run at an idle and at WOT w a non lock tire seal ve?
cummins12club
Re: Fuel pressure question
Postby BILTIT » Mon Dec 31, 2012 6:45 am
15psi is the safe number.
Derek B.
BILTIT
Postby CumminsPower59 » Mon Dec 31, 2012 8:06 am
It really depends, like Biltit said, 15psi is an average number, I personally have run 24-26psi, with no problems, but other folks have run alot lower and pushed the front seal out...
Postby cummins12club » Mon Dec 31, 2012 8:08 am
CumminsPower59 wrote:It really depends, like Biltit said, 15psi is an average number, I personally have run 24-26psi, with no problems, but other folks have run alot lower and pushed the front seal out...
What fuel system do u have?
cummins12club
Postby CumminsPower59 » Mon Dec 31, 2012 8:13 am
I "had" a cobbled low pressure piston lift pump, it had a clipped and stretched spring. I didn't know it would put out such high numbers until I installed it and ran it, I bought it used :roll: Should have bought new. I thought it was the gauge goofing up, but it wasn't the case.
Postby skilletky » Mon Dec 31, 2012 9:12 am
i have been running between 17 to 19 psi on mine for years now and have never had a problem with any of the 3 ip's that were on it.
skilletky
Postby cummins12club » Mon Dec 31, 2012 10:54 am
I want to run the highest I can I'd really like for it to be at 20 at idle but I don't want to risk blowing out the seal
cummins12club
Postby cmann250 » Mon Dec 31, 2012 11:32 am
This is just my figuring here, but if you want power/to go fast, there's an excuse to bump timing a tooth. If you're in there, Lock-Tite the seal. You can check the KDP too.
Postby cummins12club » Mon Dec 31, 2012 12:12 pm
I am about to jump a tooth in the next week or so how should I go about lock righting the seal while I'm in their? and what lock rite should I use?
cummins12club
Postby BC847 » Mon Dec 31, 2012 1:21 pm
If it were my pump, and I wanted to Locktite the seal, I'd use the GREEN product as it is designed to be applied after assembly.
It's my opinion that the other Locktite products (red & blue), being designed to be applied before assembly, are upon installation, wiped away by the interference-fit of the seal.
That being said, there's a problem with my process. The GREEN product is to be applied after the seal is installed. It's designed to "Wick" into the joint. The thing is, who says diesel fuel can't wick out the same joint? If diesel fuel isn't already leaking out, what would assure me the Locktite compound would leak in?
My point is, I think the seal's interference-fit, combined with the sealing product already on the factory seal, are gonna negate any real improvements over the original design. :?
Still, folks have done it, and apparently with good success.
Based on my experience, I don't know that the typical 12mm IP is gonna benefit from an inlet pressure of over 15psig. I'm well over 400hp to the ground with 12psig.
Postby cummins12club » Mon Dec 31, 2012 1:37 pm
Thanks for the knowledge that's what I needed to know if theirs any real benefit overv15psi what is stock psi?
cummins12club
Postby RCCUMMINS89 » Mon Dec 31, 2012 2:44 pm
I have made over 400 rwhp with 0 psi of inlet pressure (not advised) I noticed an increase in performance/response anytime I increased inlet pressure....up to 12 psi. After that I noticed/gained nothing. I recommend 12 psi at idle max. I have ran upwards of 20 psi without blowing a seal, but why take a chance. People have had issues with anything over 14 psi, not all but some.
stock psi is 3-5 psi. These readings are all post filter and what the injection pump actually sees.
Postby cummins12club » Mon Dec 31, 2012 3:37 pm
Anyone know what the pressure is on an air dog 150 set for ve?
cummins12club
Postby PToombs » Mon Dec 31, 2012 5:07 pm
Usually 15 psi on the AD.
Postby cummins12club » Mon Dec 31, 2012 5:14 pm
Has anyone had issues w the psi bieng that high
cummins12club
Users browsing this forum: No registered users and 75 guests
