I did alittle deferent on the down pipe and plus how the pipe ended up laying out,I used a stainless band and welded a bracket on the down pipe
Plus there was this taking an extra clamp where the paper work had the hanger/clamp pulling double duty
Caleb you were worried about your spare staying put,well after everything settled this is the clearance it has.
Pretty easy deal,but you'll need to trim it up with a sawsall.
in the near future it'll all be welded off solid,after I get/find the pieces to cobble together duals
