subway tunnel
Re: subway tunnel
Postby ellis93 » Thu Feb 21, 2013 7:32 am
Well....after 50miles of exhaust ran thru it,it looks like this :lol:
I did alittle deferent on the down pipe and plus how the pipe ended up laying out,I used a stainless band and welded a bracket on the down pipe
Plus there was this taking an extra clamp where the paper work had the hanger/clamp pulling double duty
Caleb you were worried about your spare staying put,well after everything settled this is the clearance it has.
Pretty easy deal,but you'll need to trim it up with a sawsall.
in the near future it'll all be welded off solid,after I get/find the pieces to cobble together duals 8)
Re: subway tunnel
Postby cmann250 » Thu Feb 21, 2013 8:16 am
Good deal. I'm going to use all band clamps from the get go. I've got 2 whole hangers on the exhaust now, so I'll have to address that with the 4" system.
Re: subway tunnel
Postby RCCUMMINS89 » Thu Feb 21, 2013 8:51 am
My goal is to run duals. I wanted to run dual 5, but Diamond Eye has yet to make a "true 5".
Re: subway tunnel
Postby PToombs » Thu Feb 21, 2013 5:35 pm
Ellis, nice weld on that bracket. 8) I like to use a regular clamp on mine there. It's easier to remove and I can shift the pipe back and forth if needed as I change stuff.
PS, it looks like the next bolt up is loose. ;)
Re: subway tunnel
Postby rockmike » Fri Feb 22, 2013 11:23 am
I didnt notice any seat of the pants dyno improvment by removing the muffler on my system...I put the ss muffler back on I prefer quiet.I sure wish I would have used those fancy band clamps,it was a bitch to get that test pipe back out of there to install the muffler...
nice install,it looks great!
93 d350 extra cab 5 speed dually.
Mods: hx35,rotated fuel pin,bosch 190 inj.,BHAF with smooth intake tube,3200 rpm spring,M&H dynamic timing spacer,isspro EGT and boost gauge,Auto meter tach, fuel press. gauge.Diamond eye 4" exhaust,Sno Stage 2 W/M kit.
Real trucks dont use spark plugs!
rockmike
Re: subway tunnel
Postby DodgeFreak » Fri Feb 22, 2013 2:23 pm
rockmike wrote:I sure wish I would have used those fancy band clamps,it was a bitch to get that test pipe back out of there to install the muffler...
If you use heat it helps expand the pipe back out to slide them out.
Re: subway tunnel
Postby Mark Nixon » Fri Feb 22, 2013 4:17 pm
I'll say this much:
ELLIS, I wouldn't get caught DEAD running that dry-rotted POS you have in the spare tire spot in that pic! :P
Re: subway tunnel
Postby oldestof11 » Fri Feb 22, 2013 4:25 pm
Ellis, did you cut where the instructions said to? I knew I had to cut but I cut the wrong pipe. Didnt look bad but I noticed it.
Re: subway tunnel
Postby ellis93 » Fri Feb 22, 2013 5:48 pm
Mark Nixon wrote:I'll say this much:
Ha ha :lol: i've never had the thing on the ground nor have I paid any attention to it,i've had on blow out before and I used the trailer spare 8) . I'm probly buying 5 tires pretty quick anyhow :puker:
Jon,I surely didn't cut where they said,well.....i didn't limit myself to "their" instructions. :lol:
Re: subway tunnel
Postby Mark Nixon » Fri Feb 22, 2013 6:08 pm
Speaking of the Diamond Eye stuff, I picked up a really rotted to hell 4X4 E/C recently with that exhaust on it.
Can I hack it and make it work on a STD cab 2WD?
Re: subway tunnel
Postby ellis93 » Fri Feb 22, 2013 7:33 pm
I don't see why you couldn't,pipe might swing wide to clear a transfef case thats not there. Bend over the axle could be different I guess.
Re: subway tunnel
Postby Mark Nixon » Fri Feb 22, 2013 7:42 pm
This snow crap has me bummed.
There is so much I can do and when the weather IS good, yet I'm too busy doing the parts thing to get my own stuff done. :roll:
Re: subway tunnel
Postby BC847 » Fri Feb 22, 2013 8:21 pm
ellis93 wrote:I did alittle deferent on the down pipe and plus how the pipe ended up laying out,I used a stainless band and welded a bracket on the down pipe
I have SO got to put a bracket on my mess. :oops:
Two days of rain, one sunny day, two days of rain, one sunny day, . ... . . :cry:
Re: subway tunnel
Postby PToombs » Sat Feb 23, 2013 3:01 pm
If you don't you'll break the flange at the turbo sooner or later. Seen it a few times.
Just a suggestion, and I know it's not really a nice option, but why not stop spending money on the truck and put up a garage? ;) :jumpsmile:
Re: subway tunnel
Postby Mark Nixon » Sat Feb 23, 2013 3:19 pm
PToombs wrote:...Just a suggestion, and I know it's not really a nice option, but why not stop spending money on the truck and put up a garage?...
For a split second there I thought you might be intimating that I can actually afford to put up a garage, then I saw they you must mean David. :grin:
This realization was garnered from the word "TRUCK" in singular, not plural, being used.
Since I have at least 4 potential projects, I feel this actually exempts me from the description.
As such, I have no real reason to reply, other than feed you a ration of crap. :mrgreen:
