Weight
Weight
Postby redneckroot » Sat Feb 14, 2009 6:22 pm
How much does the motor weigh? I'm thinking about buying an engine stand but don't want the thing to hit the floor when i let the weight on it. Also will the bolt holes in the back of the block hold it? (like the way you would a chevy 350 gaser)
redneckroot
Postby Richie O » Sat Feb 14, 2009 7:25 pm
I know my uncle has a big block he built and his stand is a 1k unit. It is very scary looking and he puts a 2x4 on the balencer to hold up the front. With it being much heavyer then that and longer in length I would go for a heavy one. I would think a 2000 lb one would be fine. I think the bare tare wieght of a 6B is around a thousand pounds.
Postby mprmn08 » Sun Feb 15, 2009 10:00 am
the book i have says 800 lbs dry.
mprmn08
Postby Richie O » Sun Feb 15, 2009 11:31 am
My 89 FSM says 880 pounds less electrical components and less flywheel. It would be close to a 1000 with flywheel, starter, and alternator. Which book is correct? I don't know. Never weighed one. :D
Postby redneckroot » Sun Feb 15, 2009 6:05 pm
I was looking at the 2000lb stand. http://www.harborfreight.com/cpi/ctaf/d ... umber=4420
But I just want to make sure the bolts or block aren't going to have an issue on the back of the block. Thanks for the input so far guys.
redneckroot
Postby PToombs » Sun Feb 15, 2009 6:29 pm
The engine stand we have at work holds the engine by the side of the block. Most heavy duty stands are like this.
The Cummins engine owners manual I have says 900lbs for a 4bt, 1100 for a 6bt. This is with the flywheel and other stuff bolted on.
Postby Ace » Sun Feb 15, 2009 6:58 pm
I don't think that stand will even come close to holding it. If you could figure out how to get the engine attached, it would fold like a soggy hot dog bun. I have one similar to that with a 440 on it and it needed braced and gusseted to safely hold up the 440. The ratings they say on those are very optimistic.
Postby Philip » Sun Feb 15, 2009 7:36 pm
Get two of those and make attachments for the side of the block. One will most likely fold up from the crank end.
I almost folded one with a BBC when I installed the heads.
Postby Richie O » Sun Feb 15, 2009 7:42 pm
I agree that picture of the 2,000 unit looks pretty scary. I would not put my legs by it. It may be rated at 2,000 pounds at the hub but not with a overhang. :shock:
Postby redneckroot » Sun Feb 15, 2009 8:50 pm
that was my feeling on it, but i wanted to see what others think. does anyone have a picture of one that the builders use?
redneckroot
Postby Mad Max » Mon Feb 16, 2009 12:09 am
Fellas, I needed a good way to not only hold a 6BT but also transport one - I started with the big Harbor Freight stand, moved the main post to the back crossleg, and added two legs up to the motor mount, and two diagonals to keep it from slipping out (which it did the first attempt).
have a look at the thread below, specifically reply # 1683, # 1789 (when it slipped out, oops) and # 1806, good to go.
http://ramchargercentral.com/index.php/ ... .1800.html
- Sam
"...there's always a way".
'78 W950 Power Wagon "Bud"
'85 W350 Crew "Big Mack"
Mad Max
Postby seeker1056 » Mon Feb 16, 2009 8:40 am
most of the guys I have seen are mounting the motor sideways off of the motor mount
This lets an ordinary heavy duty stand carry the weight without flippig over
Only down side is the motor wont rotate all the way over if the front cover or bellhousing adaptor is on the engine
Sponsors of new truck
Performance Diesel Injection
Colt Cams
H&H Offroad
Arties Transmission
Toms Contracting
seeker1056
