jwatso8 wrote:i took off one of my stock wheels and found. bolt pattern is 8x6 1/2 on 1/2 studs,(of course) the back spacing is 4 1/8 and center hole is 4 13/16. dont know the off set. hope it helps!
huntinguy wrote:The bolt pattern is, 8x6.5 with 9/16" lugs. I dont know about the hub size but I do know a ford rim will fit and a chevy won't. The chevy has a small center hole. By the way, how do you like your recap tires? I was thinking about getting some.
