Stock Wheel Specs
Stock Wheel Specs
Postby doublel89 » Mon Jan 18, 2010 5:54 pm
Feel really dumb for needing this information. Had my 91 in the shop putting a 2nd gen intercooler and hx35w in it, and somehow got talked into letting my buddy with another 1st gen try out my new tires :bh: . (Treadwright M/T Recaps). Before leaving on our adventure I quote he said 'I think I got em on there tight'. not 3 miles from my house we hit an endless pothole as i watched my wheel and tire go off the road. :mad: Now he gets to buy me a matching set of new wheels and I wanted to know the propor spec'd size. Thanks
91 3/4 Ton 4x4, 5.9 Cummins,DDP Fuel Pin I usually leave it out though, DDP 40 Horse Sticks, HX35W And 2nd Gen Intercooler, Single 5'' Trunout, NV5600 Swap, Dually Conversion, 3.08 Rear Gears, Soon A Custom Hauler Bed
doublel89
Postby redneckroot » Thu Jan 21, 2010 9:21 am
I would like to know the specs as well, mainly because I know some people have had issues with wheels out there. Anyone have info? Backspacing? diameter around the hub so they fit?
redneckroot
Postby huntinguy » Fri Jan 22, 2010 7:19 pm
The bolt pattern is, 8x6.5 with 9/16" lugs. I dont know about the hub size but I do know a ford rim will fit and a chevy won't. The chevy has a small center hole. By the way, how do you like your recap tires? I was thinking about getting some.
89 non-I/C W-250, flatbed. 4" turbo back. Ground fuel pin, AFC tuning.
huntinguy
Postby oldestof11 » Fri Jan 22, 2010 7:52 pm
The Chevy rims will work if the center is milled out. Ford Alcoa rims will work up to 98. In 99 they went metric :evil:
Postby jwatso8 » Sat Jan 23, 2010 2:50 am
i took off one of my stock wheels and found. bolt pattern is 8x6 1/2 on 1/2 studs,(of course) the back spacing is 4 1/8 and center hole is 4 13/16. dont know the off set. hope it helps! :roll:
SOLD 92 D250 intake,S300,coolertubz,i/p MAXED,366 spring,Dennyt fuel pin,DDP 4,airdog 100,gauges, 4" d/p w/5" stacks
TRADED IN07 2500 6speed,intake,CFM+,Edge EZ chip,MBRP exhaust,B&W hitch
NEW 2010 3500 6.7L DRW 4x4 CrewCab 4.10 grears
jwatso8
Postby Ace » Sat Jan 23, 2010 8:39 am
They are 6" wide, not 6.5. That's one reason wide tires on stock rims are a bad idea.
Postby huntinguy » Sat Jan 23, 2010 8:57 am
jwatso8 wrote:i took off one of my stock wheels and found. bolt pattern is 8x6 1/2 on 1/2 studs,(of course) the back spacing is 4 1/8 and center hole is 4 13/16. dont know the off set. hope it helps! :roll:
Some of our trucks have 1/2" and some have 9/16 studs.
huntinguy
Postby dpuckett » Sat Jan 23, 2010 4:05 pm
Dually wheels are 6"; SRW wheels are 6.5". Ford rims from a 97 or earlier will work, too.
Stock SRW studs were 1/2" unless you got some kind of fluke truck (like Philip's 93 with 3.07s).
DP
Postby doublel89 » Sun Jan 24, 2010 2:23 pm
huntinguy wrote:The bolt pattern is, 8x6.5 with 9/16" lugs. I dont know about the hub size but I do know a ford rim will fit and a chevy won't. The chevy has a small center hole. By the way, how do you like your recap tires? I was thinking about getting some.
I got the mud terrain ones, they are doin real good, should have put a better valve steam in though, i've been religious about checking pressure and keeping them up to 80 psi, i wouldn't get as agressive of a tread it makes the truck way way too touchy for my preffered driving style, but all in all they're pretty good.
doublel89
Postby huntinguy » Sun Jan 24, 2010 4:53 pm
Thanks man! But what is your preffered driving style? LOL
huntinguy
Postby doublel89 » Tue Jan 26, 2010 8:42 pm
ha ha i couldn't bs up a better term there, what i mean is that they grab the road more than i like. i had some bfg all terrains on the front, they sucked because on a hot summer day you could watch the tread wear off them, but they weren't near as touchy as the mud terrains. hope that explains it better
doublel89
