Spencer
spencermumma wrote:hey i have a 1990 cummins and wondering what size turbo i should get this winter i have a new transmission going in and i also have 6x16 and 14mm rotor head going in at the same time wondering is a 64/71 to small do i need to go with a 66mmwhat are your thoughts?
Spencer
spencermumma wrote:thats what i was thinking so what single turbo would you recomend?
thanks spencer
spencermumma wrote:would thatbe a good turbo to keep egts down?
Richie O wrote:I suspect it would spool pretty good until you put a lot of timing in. RSWORDS has a similar set up with 2 teeth advanced and has trouble getting it spooled.
spencermumma wrote:if i were to run twins whats best setup?
peobryant wrote:
Is that much timing even needed? That much seems a little extreme to me.
