what fuel filter to use?
Postby Tsbourne09 » Fri Nov 11, 2011 2:57 pm
Im changing my fuel filter again when i put my raptor150 on and was wondering which one to use?
Not On Yet: 60#VS
Tsbourne09
Re: what fuel filter to use?
Postby mike8061 » Sat Nov 12, 2011 10:31 am
Are you talking about a filter for the stock location or a seperate unit entirely?
92/93 W250 Ext. Cab. LP lift pump, 3200 spring, fuel screw maxed, pin almost ground through, 6" lift, flat bed, 35x12.5, big bumper
93 ext cab parted
92 reg cab parted
1967 C50 swapping in spare 5.9 auto and 205. 8.10 low in rearend. should pull somthin
mike8061
Postby Tsbourne09 » Sat Nov 12, 2011 4:24 pm
the stock location. the raptor does not bypass stock filter.i think?
Not On Yet: 60#VS
Tsbourne09
Postby mike8061 » Sat Nov 12, 2011 5:04 pm
I was just asking as some people bypass the stock filter and use a seperate unit as the stock can be resrictive at high flows.
There have been part numbers posted for a larger filter that goes in the stock location but when I tried last year I had no luck finding any. So i went with a seperate housing and a large filter/water seperator thats cheap at the local truck shop.
93 ext cab parted
92 reg cab parted
mike8061
Postby cmann250 » Sat Nov 12, 2011 6:46 pm
I'm not 100% sure, but i don't think the raptor bypasses the stock filter. I just got the Fleetguard filter from Scheid. FS1232 or FS1253 is the Fleetguard PN
Postby Tsbourne09 » Sat Nov 12, 2011 8:04 pm
Im 100% sure it does not bypass the stock filter. I just found this on dtr. Is that what you are talking about?
http://www.dieseltruckresource.com/dev/ ... stcount=16
Not On Yet: 60#VS
Tsbourne09
Postby cmann250 » Sun Nov 13, 2011 7:26 am
Those are bigger filters than Cummins intended for you to use on a 5.9L, but they won't hurt anything. I just got the stock one because it's cheaper
Postby Douglas » Fri Dec 16, 2011 5:00 am
hey-Hey!!!,
Just saw some discussion on the FS1221. Longer filter but it does away with the water sensor. Not sure I am comfortable with that though. Seems to have a 22 micron rating v. 25 for the stocker.
cheers,
Douglas
1991 D250, 727 and 16cm H1C.
Douglas
Postby 91bluecummins » Fri Dec 16, 2011 12:16 pm
when i put my rator 150 i by passed the stock fuel filter and ran from pump to filter to IP
92 cummins W250 extenged cab (The Goat) project truck
90 cummins W350 single cab dually flat bed 5 speed, he351ve 62mm
1959 chevy Apache 4bt cummins 4 speed
91bluecummins
