max MPG!
max MPG!
Postby Broncman » Tue Dec 06, 2011 5:22 pm
Most people get caught up in the horsepower and speed of these motors. What is the max economy one can pull from these. Has anyone got into the 30's !
Broncman
Re: max MPG!
Postby cmann250 » Tue Dec 06, 2011 5:28 pm
JQmile has gotten north of 25 mpg (27?) in a 2wd with a 47RH. I hope to be able to duplicate or exceed those numbers soon
Re: max MPG!
Postby 1990 » Thu Dec 08, 2011 7:35 am
I've gotten 24 MPG with a 2wd Getrag Non I/C. I used to average 20-21 MPG though.
2012 Subaru WRX TP Stage 1 DD
Re: max MPG!
Postby oldestof11 » Thu Dec 08, 2011 4:26 pm
Guy on CompD has compounds, a hamilton MPG cam, bigger sticks (DDP4's), P-pump, manual, and a GV OD unit. Extended Cab Long Bed 2nd Gen. Squeaking about 35mpgs repeatedly.
Re: max MPG!
Postby Broncman » Thu Dec 08, 2011 4:32 pm
I got 24 on my first fill up of the conversion. Only about 50 miles of that was towing. Working on my second tank but having trouble keeping my foot out of it :mrgreen:
Broncman
Re: max MPG!
Postby CumminsPower59 » Thu Dec 08, 2011 8:18 pm
Shoot, I'd be happy if I could get 20mpg...highest has been 19.96mpg :x
Re: max MPG!
Postby ahale2772 » Fri Dec 09, 2011 5:07 am
I think you can afford to round up 8)
Re: max MPG!
Postby CumminsPower59 » Mon Dec 12, 2011 5:49 am
I know :roll: but for once, I would like to hit 20. I wouldn't mind taking it on a trip where I can run for several hours and really check, the longest my truck has been driven since SOP is to Cedar Rapids IA and back only one hour from the house :lol:
Re: max MPG!
Postby PToombs » Mon Dec 12, 2011 6:31 pm
Quit drivin' the Vdub! :lol:
Re: max MPG!
Postby CumminsPower59 » Mon Dec 12, 2011 7:50 pm
Dang it Pete! Driving the Vdub is the only way I can afford to run the 92 :( , but now that the snow is coming, I won't be caught dead driving the "cah", the 92 is just about my only way to bust through the snow in my area on my daily 5 a.m. commute, the roads aren't bladed around here often... :roll:
Re: max MPG!
Postby Deathrod » Tue Dec 13, 2011 7:08 am
Before i ripped my truck apart it was avg around 25 mpg on my commute, it was a 91 non i/c with pump upgrades and straight piped.....and this was with the stock 727.....Just about everyone I have told says its bs, no way it got that with no od, but it did. btw it was 2wd, single cab.....hoping i can break 30 with od and a lighter car!!!!
Deathrod
Re: max MPG!
Postby BCOWANWHEELS » Sun Jan 01, 2012 3:17 pm
for milage I,ve found its real hard to beat a stock engine. I would be interested in learnning about that mpg cam though.
I BELIEVE IN JOHN 3:16
BCOWANWHEELS
Re: max MPG!
Postby meby » Sun Jan 01, 2012 7:41 pm
The best i've gotten in my not stock, 2wd stick is a bit over 25 mpg, my dad has gotten 28 in his stock 4x4 stick.
-1991 D-250 bone stock
-1997 Civic Hatchback
-Case 530 CK
-Speedex Walking Tractor.
-BCS Walking Tractor
www.ebyfarmsllc.com
meby
Re: max MPG!
Postby cmann250 » Sun Jan 01, 2012 7:49 pm
I hit 20.8 once back when i had the 727 and the injection pump wasn't stock. I can't remember is i pulled any hay wagons that tank or not :lol:
I swapped in that 47RH having dreams of 25+ mpg, but i promptly killed it :roll:
Re: max MPG!
Postby bmoeller » Tue Jan 03, 2012 6:20 pm
Got 20.0 mpg out of mine before. :D 400 miles round trip to WI. The stock H1C w/ 21 housing too boot.
Checked my 1st tank since the HE351Ve swap. 14.6 (but just short trip crap). :( Usually 17-18 range before, in those conditions.
Bumped the timing when I put the VE back on after I replaced the tappet cover gasket this past weekend. Only 28 miles since, so we'll see. If it still sucks, I'm getting a rebuild kit for the H1C and its going back on. Probably put a GDS 60 and 14 or 16 housing on it though.
SOLD- '99 3500, SO CTD, 5spd
bmoeller
